Ether
   / Ether #1
70jd400
Member
Fitzwilliam NH
JD 400 Industrial
So I have never used the ether on my tractor. There is a spot to screw on an ether can below the steering wheel. My question is where can I get an ether can that screws on
   / Ether #3
I've never seen something labeled John Deere and only costing $4.00. :laughing:
Buy two.
   / Ether #4
Use it sparingly, back in the days before glow plugs many diesels cylinders were prematurely worn out due to excessive ether use.
   / Ether #5
70jd400
There one thing you need to know. The following is how I was taught when I was employed at a JD dealership from '66-'87. The starting fluid(ether) can will not screw on the JD 400 factory starting aid bracket. One needs to remove caps on both the bracket & starting aid also removing the top spray nozzle on starting fluid. While turning engine over when can is held up "briefly inside bracket" a shot of fluid will be sent down pipe to intake manifold which contains an orifice that limits amount of fluid that can be induced to engine at one time.
   / Ether #6
I have read about holding a rag in front of the air intake on a diesel,, soaked in gasoline,,
the gasoline fumes aid in starting a cold diesel,
This seems safer than ether,, if it works,,
Does anyone have first hand knowledge of gasoline fumes aiding in starting a diesel??
   / Ether #7
Holding a gas soaked rag in your hand sounds safer than giving a shot of ether from a spray can?
   / Ether #8
Yes gasoline on shop towel held over open intake will substitute for starting fluid as a starting aid. BTDT
   / Ether #9
I know a guy that ran his Duramax out of fuel, the batteries were weak,,
so,, rather than extensive cranking, he dribbled a few drops of diesel into the engine somehow,,,
upon cranking, one of the pistons promptly exited through the side of the block,,, :confused2:
So,, I am a little shy of doing anything like that,,, :eek:
   / Ether #10
CADplans
There has to be more to the story of the pistons exit'ing through the side of the block, than those few drops of diesel. Much more, IMO. ;) just sayin.....
Case CX80C (A50123)
Case CX80C (A50123)
Toro Mower (A50324)
Toro Mower (A50324)
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
