Backhoe how to tighten BX23S backhoe hydraulic nuts
   / how to tighten BX23S backhoe hydraulic nuts #1
realpdm
Georgetown, TX
Kubota B23s
I have a new BX23S (a week old) and I found I had a leak coming from the backhoe (stain on my driveway! (need to look to see how to clean this up!)). Anyway, I tracked the leak to these connections pictured below. The problem is it is very very difficult to get my wrench in there to tighten them. Is there a special tool to tighten these or just go a little bit at a time with my regular wrench?
Ooh! Thanks. That is basically what I was imagining but had no idea what it would be called.
   / how to tighten BX23S backhoe hydraulic nuts #4
There are the open end ones, the pictured 12 point socket ones, and 6 point fitting ones (strongest but thickest).
   / how to tighten BX23S backhoe hydraulic nuts #5
Yes the tool is called the dealer who delivered it leaking.
   / how to tighten BX23S backhoe hydraulic nuts #6
Oh...yes, I missed the week old part.:eek: Yes, they should be jumping to fix that for you!
Yes, they did say they could send someone out to fix it but if its just tightening a nut I figured I could manage that (with new tools!). However, it has probably lost enough I need to replenish the hydraulic fluid so maybe better to let them come do all that. Thanks for help!
   / how to tighten BX23S backhoe hydraulic nuts #8
It's under warranty..I would have the dealer fix it if possible.. but if that is a pita.. I have taken a old Craftsman box end wrench..and ground out a slot that would slip over the hose and onto the fitting I needed to get tightened. ..worked great.
2012 SANY SRC 840 40T Crane (A60460)
2012 SANY SRC 840...
2014 Jeep Grand Cherokee SUV (A56859)
2014 Jeep Grand...
2011 20ft. Anderson Lowbed Trailer (A56859)
2011 20ft...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
