anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit?
   / anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit? #1
spokane 1
Spokane Wa
Montana 3040
will a sos trans (back half) from a 62 ford 4000 fit a sos on a 58 ford 861? the motors are all 2.8.
the tractor data suggests everything is the same. this should be a double disk clutch inside....requiring a 7502 tool to line up. 00A0A_haKBNPYmdkp_600x450.jpg
   / anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit? #2
Looking at parts digrams on Messicks New Holland parts site sure looks like it will swap out. Check it out.
   / anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit? #4
N
the tractor data suggests everything is the same. this should be a double disk clutch inside....requiring a 7502 tool to line up.View attachment 580937
The answer to the question as posed is yes. Problem being, if the photo is purported to be of the 1962 4000, it is not a 1962 4000. The photo is of a 1965 or later 3 cylinder tractor and the transmission from it will not bolt up to those tractors referred to as 4 cylinder prior models. So if your question is will the pictured transmission bolt up to an 861 the answer is a firm no.
   / anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit? #5
N
Am I the only one who RickB reminded of Marisa Tomei (the expert mechanic) in "My Cousin Vinny" when she testified in court?
Rick,
In case you haven't seen "My Cousin Vinny", that was a compliment.:)
   / anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit? #6
Don't most opt to switch out the SOS, not try and save it?
   / anyone a pro on ford tractors.? will a sos trans from a ford 4000 fit? #7
Yes. But none of the transmission options available for the pictured tractor will bolt up to an 861. Which by the way, if equipped with an SOS transmission is not an 861 but rather an 871 or 881.
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
UNUSED X-STAR 8' X 40' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 8' X...
BUSH HOG 3308R-2 LOT IDENTIFIER 106 (A53084)
BUSH HOG 3308R-2...
