to flux or not to flux?
   / to flux or not to flux? #31
I would bite the bullet and get a gas bottle. And all the guys that keep saying they buy 2 pound rolls. A 10 or 11 pound roll in a welding supply store cost the same as a 2 pounder at the box store
Yes I think that is the way to go as well. Now the million dollar question is who makes a unit with the best "bang for the buck" capable of occasional use welding steel up to say 3/8" thick ? I wonder what a good, solid, DC MIG welder with tank runs for esp one that does not have a lot of extra or fancy features that I cannot afford?
   / to flux or not to flux? #33
Low end.... HOBART... Economy line to Miller...
For 3/8, probably the 210MVP or Ironman 230....
I have Hobart Handler 140 and it is ok up to about 1/4 inch, beyond that some preheat and multiple passes.... And If I knew then what I know now about MIG welding I would have gone minimally for the 210MPV...
As for wire spools 2 pound vs 11 pound, I use so little I would rather have a 2 pound spool lost to rust/corrosion from sitting in poor environment then lose a 11 pound roll from just sitting...
Dale
Dale
Hi Dale. Super ! Excellent info and I thank you. I will check them both out. I do have 220 VAC available, same outlet I use for my AC buzz box stick welder (which BTW I am ready to convert over to DC after I found some lunker stud diodes in my junk box).
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
Kubota L3130 (A53317)
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
Booster Cables (A59230)
Booster Cables...
