balsam
Member
I am planning on building a tracked vehicle that I can use for ice fishing. I have a circuit in mind that should operate like braked steering used on most of them. Normally a differential is used and each output shaft is braked to slow or stop the track causing the other to turn faster, thus turning the vehicle.
Often, using hydraulics, tandem variable displacement pumps are used to individually drive each side which allows for a zero turn radius, something I don稚 need. Totally stopping one side will allow me a turning radius the width of the machine.
I think I can achieve results similar to the differential system hydraulically, with a variable displacement pump, driving wheel motors in parallel. By restricting flow through one side or the other, the restricted side will slow causing increased flow to the opposite, causing the turn.
I have worked out most of the kinks, like reversing, and where to place the restrictions(metered out) but I can稚 think of a flow control valve that I can use. I need to be able to vary the flow from full to nothing, hopefully using a joystick or wheel.
There must be a valve of some kind that I can even modify to do it.
Hopefully I have explained my problem and someone can help.
I may try to figure out how to add a schematic of the circuit on here.
Thanks in advance
Thanks in advance
