Keep getting flat tires
   / Keep getting flat tires #1
Seamonster124
Member
WA
BX1880
Not sure if changing tires would help or am I doing something wrong? My BX came with turf tires. 2 flats in 3 hours. I'm basically cleaning up piles of yardwaste. Little branches are poking through the tires.....When I repair the holes its pretty obvious the turf tire is super thin.
- I know bar offers more traction but is it more puncture resistance?
- Do you have a favorite online source for tires?
- Possible to replace the tires without any specialty tools? I'd like to keep the rims
   / Keep getting flat tires #2
Correct, turf tires are not known for being resilient or puncture resistant. The R4 industrial tires are the most resilient and durable tire that you will put on the machine.
   / Keep getting flat tires #3
Seamonster - if you will continue cleaning up yard waste - it may be time to look for some R-4's or even those steel chord protected/reinforced tires used in the logging industry. Two flats in three hours - that is simply too much and does not give a bright outlook toward the future of similar occurrences.
Thank you. R4 is tougher than r1? Also, r4 if different than bar?
   / Keep getting flat tires #5
Is it the plies on the tires more then the style.
Are many of the turf tires just 2 ply.
Where as most R1's are 4-6 ply,
and many R4's are 6 ply tires.
I don't run them but can you find turfs in a 6 ply?
   / Keep getting flat tires #6
Absolutely. The R4 is the toughest tire of the common options by a pretty big margin. They are built for skid steer work on demolition and construction sites. If you knew what I do with mine and it's R4 tires, you'd be shocked that I've not had to replace them yet.
   / Keep getting flat tires #7
It's more than simply the plies. A piece of rebar wouldn't care about plies. It's about steel within the plies, some tires layer in Kevlar as well as steel. A turf is a very thin and soft tire with only the minimally required reinforcement built in.
The AG tire is not a whole lot better, but it is a more robust build. An R4 is specifically built live in a world of danger. The R4 will also bare loads much better than the turf or the AG.
   / Keep getting flat tires #8
Yes - the R4 will be tougher, have much heavier bars on the tread and much stiffer side walls than the R-1. If you are changing from turf to R-4 or R-1 you should be advised - you will, most likely, need new wheels. Generally speaking each type tire will require its own matching type of wheel. And if your BX is 4WD - then the front/back tire sizes MUST be matched to the sizing required for safe 4WD operation.
So theres more to it than just matching these numbers?
Rear: 24x12.00-12
Front: 16x7.50-8
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
Tires (A50322)
Tires (A50322)
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
