Keep getting flat tires
   / Keep getting flat tires #11
The IDEAL situation - your owners manual tells you the tire size for R-1, R-3 & R-4. However - I'm willing to bet that will not be the case. Me - I would go to a tire store that - 1) you know you can trust 2) sells and deals, specifically, with tractor tires 3) willingly acknowledges your wishes and takes the job on professionally.
Quite honestly - you DO NOT need R-4's that exactly match the sizes you have listed - those are your terf tire sizes - right? Of course, you shouldn't go to a tire that's 36" high. What you need is a bit difficult to describe -
You need tires that have the same ratio of size - front to rear - that those turf tires have. So if the front tire has a rolling diameter of 20" and the rear rolling diameter of 40" - you need to keep the same ratio on new tires. ( Front - 15" rear - 30" ) ( Front - 24" rear - 48" )
Common sense will dictate that overall you will want the new tires to be close to the same size as the turfs.
Hoping to just do it myself.
Manual says same size for turf and bar....assuming "bar" mean anything other than turf
   / Keep getting flat tires #14
I’m reasonably certain that R3 and R4 Tire’s for a BX are the same relative sizes, but the Op manual will confirm or refute that. There is not an R1 option and finding suitable R1 sizes will be problematic and perform unsatisfactorily in many situations a BX is typically used.
   / Keep getting flat tires #15
Thank you, sufficient even if I do not replace the rims?
IF you can find tires of the same size (diameter and width) then the same size wheel should be fine. I do think on the subcompacts all three major tire types (R1, R3 & R4) are all the same size. Compact and larger tractors often have different tire sizes between types, most notably between R1 and R3/R4. R1s tend to be taller and narrower, dictating a narrower and larger diameter wheel.
   / Keep getting flat tires #16
I don't know how much rims will cost, but in the grand scheme of things you might be better off with complete rim/tire sets for each. And just so you know, wrestling a stiff R4 tire onto a rim is no picnic. Dealing with small tires is already a PITA, and R4 tires make it even more of a challenge. This is not like working on a typical car/truck tire. I'd talk to your dealer and see what they charge for the full wheel/tire set (which is how they get them from Kubota).
Was there a reason you got turf tires to begin with? Will you want to switch back to turfs for certain tasks, like mowing a yard? I wouldn't hesitate to mow a field with R4 tires, but if you have manicured turf that you care about, the R4s will damage it with repeated mowing.
   / Keep getting flat tires #17
"Bar" is the R1/Ag equivalent on subcompacts, but different than R4/Industrial. You want R4s for your application.
Tractor data implies that for the BX2660 I looked at, all three types are available in the same size.
   / Keep getting flat tires #18
What I've learned with front tires and two different tractors is that a new tire works great for a period of time, but eventually it breaks down and starts to get flats. I have R-1's on one tractor and 18 ply tires on my backhoe. I tried slime and that worked for awhile, but then it doesn't. Then I had to go to tubes, and that was OK, but I still go flats. Eventually I tried foaming the front tires and I haven't dealt with a flat in about ten years now. The R-1's need replacing. There are some big holes in them and the tread is starting to tear apart. I might get another year out of them, but might just buy new tires and have them foamed again next year. I'll never have a tractor without foamed front tires again. It's cheap to have the repair shop fix the flat, but it takes up too much time and ruins the rest of the day to get anything done.
   / Keep getting flat tires #19
Something that nobody mentions when they sing the praises of R4 tires is how much rougher they ride than turf tires. I solved my turf tire puncturing problems by buying 6 ply turf tires.
   / Keep getting flat tires #20
From what I can tell, the BX1880 does not offer R4 tires as an option, I believe because R4s are not made in that smaller size.
You MAY be able to go up one size.
The BX2660 I mentioned above takes these sizes:
Front: 18x8.5-10
Rear: 26x12-12
They might fit on the same rim size - not sure.
Note that you will be losing some effective power pushing/pulling power by virtue of the larger diameter of the tire. AND you probably will void the factory warranty if you do so.
Bar tires may be ruggeder, not sure. If so I would say that is your best option unless you can find some more heavy duty Turfs.
STORAGE FEES (A52576)
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
RV Hitch (A50121)
RV Hitch (A50121)
