Kubota RTV 1140 cpx
   / Kubota RTV 1140 cpx #1
Pat2288
Kubota RTV 1140 cpx
Trying to diagnose kubota why it doesn稚 move forward and reverse in 2 wd but it moves in 4wd need help if anyone has had this problem before thanks.
   / Kubota RTV 1140 cpx #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Kubota section to see if we can find you an answer.
   / Kubota RTV 1140 cpx #3
my buddy had same problem and both the back hubs were stripped out.its a common problem on them from what we were told
   / Kubota RTV 1140 cpx #4
I have a RTV1140 that I've owned for 8 years with zero issues other than learning how to depress brake pedal to shift gears, apply emergency brake and hand pressure on lever from 2 to 4wd till it just slides in or do it stopped. I've been a member on this forum for about 12 years and never heard of this issue personally or here on this Kubota forum.
   / Kubota RTV 1140 cpx #5
If problem isn't stripped rear hub then I'll guess broken rear axle or spider gears/shafts in rear differential.
   / Kubota RTV 1140 cpx #6
Yup^^
The rear hubs on X900, X1120 and X1140 are the same and I have not seen a stripped hub yet. The rear hub recall pertained to a material change in the hub housing.
   / Kubota RTV 1140 cpx #7
Check the 2 to 4 shift linkage, probably not moving the full distance needed
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
New/Unused CFG Industrial QK18R Mini Excavator (A51573)
New/Unused CFG...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
