MF135 Tie rod ends removal
   / MF135 Tie rod ends removal #1
CharlieDelta
Australia
Massey Ferguson 135
Hi
I am trying to replace the tie rod ends on my straight axel non radius MF135. I am having difficulty removing them.
I have removed the nuts and I am trying to pop the ends out but they dont want to budge.
Do I have remove the whole drag link and unscrew the end out or is there some other trick. I did try a rubber mallet but they dont want to budge.
I will be changing both the front and rears on both sides while I am at it.
I have looked in the parts manual and it seems to indicate that they are held in with the nut.
If I cant get them to move I will have to remove the whole drag link from the axel and steering box arm to get the ends out.
Aby tricks or tips?
   / MF135 Tie rod ends removal #2
Remove nut then hit on arm near the balljoint with a hammer . Mybe 2 hits and it will jump out !
   / MF135 Tie rod ends removal #3
Even better to hold a small sledgehammer tight to one side of the steering arm while whacking the opposite side. Have the nut loosely installed on the rod end to keep it in place when it pops loose.
   / MF135 Tie rod ends removal #5
Or things like this 20060829-tie-rod.jpegTIE-ROD-AND-BALL-JOINT-PULLER-2.jpeg
   / MF135 Tie rod ends removal #7
He talks about a MF 135
   / MF135 Tie rod ends removal #8
Doesn’t matter. The method works on all brands. I’ve used it on everything from an 8N to a Deere 4430. Not much different than your method except the mass of the stationary hammer increases the shock on the rod end socket.
Thanks for all the tips.
I have managed to get 2x drag links out. I do have a pickle fork its just too small I bought it to use on a car.
The last 2 tie rods are really stuck. Since I am replacing all of them would a bit of heat and quick spray with one of those freeze sprays help anything?
I will stick with the brute force methods and see if I can get lucky.
Thanks again for all the assistance and tips.
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2024 JOHN DEERE FC 10 R LOT IDENTIFIER 79 (A53084)
2024 JOHN DEERE FC...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2018 John Deere 1653 (A53472)
2018 John Deere...
