Snow plowing on soft ground
   / Snow plowing on soft ground #1
dae06
Minnesota
Kubota B2650
First off, I've searched and didn't find what I was looking for, so I apologize if this has been posted before. I know it drives some people crazy to have repeated subjects posted.
That being said:
I have a FEL mounted 73" front blade with hydraulic angle and tilt functions. This is on on a New Kubota B2650 and used on a new gravel driveway. I live in Minnesota.
Issues:
The first few snowfalls so far this year have been wet, heavy snow and the ground being very soft. Using float is definitely not an option on soft gravel. I dug up soooo much gravel my first time out and would like to hear what I am doing wrong and what I need to do to make this work. I have a 300' driveway with a 10 degree slope and with slightly sloped (side to side) curves and a 20' drop off on the sides along with another 300' of level gravel roads to clear.
I've tried manually controlling the front blade with some success, but I would dig in sometimes and lift the blade too high other times, so it looked like a child plowed my road. I've tried tilting my blade forward and backwards, using the skid shoes and taking them off. I just can't seem to find the best scenario. Once things freeze up here, I think things will go much better, but I would really like to hear what others do in the soft ground situation.
To be honest, I have a rear box blade and ended up using that, but this is much more time consuming with all of the going forward and backing up involved. If the front blade would have worked like I thought it should, it would have gone much faster.
All suggestions and ideas are appreciated.
Thanks
   / Snow plowing on soft ground #2
dae06- Welcome to TBN.
I do not know your level of experience with tractor operation, but you addressed your snow management challenges logically and pretty thoroughly. It seems that you need a little more practice and need to find the mix of settings that works for you. Once those high and low points form on the plowed surface one is basically screwed until some degree of level is re-achieved on the area being plowed by backdragging the bucket/plow and/or using the box blade.
I've been there years ago with my old Ford 1100 and a dual hydraulic plow that worked best tilted backward and not angled on the initial pass as the edges would tend to dig in. Now I use the FEL and box blade to manage my snow. Float position with the FEL angled slightly up works for me with the box blade essentially level. I made plenty of mistakes in +30 years of "learning curve" experiences. Moving snow on soft surfaces still requires focus.
I am sure there are other owner operators here who can offer their experiences which are different than mine.
Good luck.
   / Snow plowing on soft ground #3
Going through freeze and thaw cycles make it tough on plowing a gravel drive. Today it’s 26 degrees and my driveway is frozen solid, tomorrow it’s going over 50 degrees and lots of rain moving in.
For me and my driveway, preparation is the key. I get it as smooth and compacted before the first snow hits. Due to the width of the drive and the width of my plow, maintaining a crown is a fools errand. Even with lateral float on the plow, the first time down has a real leveling effect.
Additionally after the first plowable snow, I now have created a bank that holds back water during those freeze thaw cycles, crown or not.
What works best for me during the early season and less than 3” of snow is to plow the paved portion of the driveway by the house and just drive on the snow on the 1/4 mile gravel portion and pack it down. If I get more snow than that and I have to plow I lower the plow just until the shoes barely touch. Additionally, I tilt the blade back so it’s at least 2” above the gravel and go at it. The majority of the weight of the plow is on the FEL arms so even on a soft drive you don’t get very much digging in or movement of gravel.
Once it freezes and stays cold it get pretty easy, but until then it can be problematic. Good luck!
   / Snow plowing on soft ground #4
I have the same scenario at my place. I either use the box blade or drag the snow blade backwards. I don’t try to remove the snow as much as just pack it down.
Once it’s frozen the setup works great.
   / Snow plowing on soft ground #5
I have the same setup. PA blade w/ hyd. angle on my tractor. First few snows with soft gravel I lower the blade and pick it back up about an inch or so. Can't put it down all the way because even the shoes will dig up gravel. Even now the gravel drive is not frozen so have to be careful.
I have a blower on the 3 pt. but if I didn't I have used a back blade turned around 180 degrees to plow without pulling up the gravel.
   / Snow plowing on soft ground #6
   / Snow plowing on soft ground #7
Do you have adjustable shoes/slides for the plow?
   / Snow plowing on soft ground #8
one idea that works well is to add on some additional surface area to the skid shoes, sometimes you can
find existing steel laying around or just make them, but a large skid shoe of say 12" square may help keep the blade
in a better position.. it would also help to bevel the front and back edges of the shoe up so they don't dig
in. all depends on what you have for shoes now and how much room you have to work with. we have
done it on snowblowers with good success
   / Snow plowing on soft ground #9
When my drive was gravel I used a rear blade spun around 180 degrees also.
   / Snow plowing on soft ground #10
Any amount of moving snow will result in damage in my experience. Conditions are just too variable. Really, my own solution. Move snow as little as possible. Have a 4WD vehicle and I put a sign up warning people of limited winter maintenance. It makes for so much less work in the spring.
10' WROUGHT IRON SITE FENCE (A58376)
10' WROUGHT IRON...
1000 Gallon Fuel Tank (A57149)
1000 Gallon Fuel...
2020 Deere 50G (A53317)
2020 Deere 50G...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
