Garage door seal lubrication
   / Garage door seal lubrication #11
I glued down some rubber weather stripping on the concrete. This created a ridge and a better seal to the bottom of the door. It has held up great for the last 5+ years.
   / Garage door seal lubrication #12
I've had good luck with WD-40 on door weatherstrips. "WD" stands for water displacement, I've been told.
As fate would have it, I had some WD-40 on the shelf in the garage so sprayed the door seals about a month ago. So far so good - no sticking.
Thanks for all the replies.
   / Garage door seal lubrication #15
Johnson's Paste wax applied liberally with an old sock.
   / Garage door seal lubrication #16
windshield washer fluid will get it unstuck even if frozen
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2017 Hitachi ZX245USLC-6N (A47477)
2017 Hitachi...
