YooperJim
- Joined
- Oct 29, 2018
- Messages
- 3
- Location
- Upper Michigan
- Tractor
- 1971 John Deere 500b; Kubota L4240; Kubota BX2350
No good deed goes unpunished. Borrowed my 1971 JD500 loader/backhoe to neighbor for several days. It had very few hydraulic leaks mainly only on the loader valve a pressure relief valve would weep. Nothing serious. Neighbor returned unit and made comment a little leaky but runs great. Didn't think much at the time. A few weeks later went to use the unit and saw a 1/2 empty 5 gallon pail of hydraulic fluid in the cab (Gold brand something) and realized the neighbor used this to top of the hydraulics. I do not believe it is the universal 303 fluid that is required for this unit - which i have used religiously since owned for the past 15 years. Yikes. Started up the unit and immediately noticed a steady stream of hydraulic fluid coming out of the hydraulic pump area. Upon further investigation looks like it is leaking at the hydraulic drive shaft bearing. I then checked the overflow line which was returning a steady stream to the hydraulic reservoir (which normally was only a steady trickle).
My question now is how do i completely rid the unit of hydraulic fluid and get it back to JD 303 specs before beginning to work on the hydraulic pump leak (note: have not noticed a degradation in performance or other leaks yet)? If i simply drain the hydraulic reservoir and change filters what about the remaining fluid in in the system/pistons/brakes/steering etc.? Ugh.
