service light
   / service light #1
drolen01
mahindra 7060
Hello all
I'm new to the forum. Does anyone know the procedures to reset the service light on and Mahindra 7060.
Thx
   / service light #2
Not 100% but a lot of folks claim the OBD2 scanner can clear it. Have you found the OBD2 port and plugged in the scanner?
   / service light #3
I would think disconnecting the battery, usually just the negative, disconnected for a few hours would reset it.
   / service light
NO I don't have a scanner
   / service light #5
They are about $25. Most folks claim it will clear the codes and lamp. Some machines/autos clear the codes after a set amount of time without power but it could be an hour or it could be a week. The code reader may be an option that wastes less time or aggravation......assuming it clears the codes. Worst case is you have a reader for your autos.
   / service light #6
On my 6520, there is a little holder that looks like an inline blade fuse. I remove the cover, turn the key on and wait 10 seconds, then jump across the terminals with the key on. That resets it. Sometimes it takes more than one try to get it reset. It is right beside the fuse block.
hugs, Brandi
   / service light #7
Not sure if the OBD2 can reset the light but just beware if you try to use an OBD2 to read codes on a Mahindra you will not get the correct codes. Mahindra uses a proprietaty software for reading the codes.
   / service light #8
hugs, Brandi
That’s an interesting find! Thx for posting...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
Navigator 4000 4,000lbs Forklift (TRUCK MOUNT) (A52128)
Navigator 4000...
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
