Dt466 smokes terrible and I can’t figure out why.
   / Dt466 smokes terrible and I can’t figure out why. #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I’ve got a international truck that used to be a fire truck. Its got 212000 miles and 7,000 hours. It smokes white smoke at an atrocious level. I’ve pulled two injectors and had them checked and they said they were good. I’ve compression checked those 2 cylinders and they’re close to 300 psi. I’ve pulled the hose of between the turbo and the engine to check for oil being blown in and there is none. The truck seems to run pretty good. It had a miss when I bought it but I drove it home and it doesn’t seem to be missing anymore.
   / Dt466 smokes terrible and I can’t figure out why. #2
Are you having to add water? If so you are probably looking at a gasket problem. If you are using a lot of oil then best bet would be to find a good diesel mechanic for troubleshooting. With those hours and miles it is just getting broke in.
   / Dt466 smokes terrible and I can’t figure out why. #3
A mechanically injected DT466 is more than ready for an overhaul at 7000 hours.
The truck is too bad to drive and the 10 mile trip home is all I’ve drove it. And the water pump seaps anyway. I don’t think the head gasket is bad.
   / Dt466 smokes terrible and I can’t figure out why. #6
To me, white smoke suggests water/coolant leaking into combustion chamber.
   / Dt466 smokes terrible and I can’t figure out why. #9
This.
It's not oil related. You either have a bunch of water in your fuel, or a coolant leak that's leaking into your cylinder(s).
   / Dt466 smokes terrible and I can’t figure out why. #10
Wouldn’t that leak water into the cylinder and hydro lock it?
Depends entirely on how big the pinhole is and how far from the top of the sleeve. Cavitation erosion usually occurs in the bottom half of the sleeve. Everything is a guess until some real troubleshooting happens. 4 more injectors to pull and 4 more holes to do compression tests on. Then pull the oil pan and pressurize the cooling system before pulling the cylinder head. Oh, yeah, reinstall the fuel injectors before pressurizing the cooling system. You don’t want to push out any injector sleeves.
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
Electric Mobility Scooter (A51694)
Electric Mobility...
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
JOHN DEERE 6130M TRACTOR (A51243)
JOHN DEERE 6130M...
