L3560 with BH 92 and AG's
   / L3560 with BH 92 and AG's #1
Kubota 2007
PA
Kubota L4740,B3030,ZD326, RTV 900,L4200 1120RTV
Considering purchasing a L3560 (foldable ROPS)with BH92 and Loader with AG's can anyone give me the overall height of Backhoe when locked/stored for travel.
   / L3560 with BH 92 and AG's #2
I don't know if this helps or not, but this has the height of the backhoe at 100.1". Found the info here if it helps your research.
Kubota | BH92
Thanks DOES hELP
   / L3560 with BH 92 and AG's #4
To install My BH92 you do not have to take the lower lift arms off the 3 point hitch but it is recommended. *I heard damage could be cause if you leave them on. *Trying to assess is it worth take the lift arms off so trying to find out what kind of damage can be done and what action causes the damage ..etc.. mistakenly lifting the arms when the bh is on. *Some arms got bent some how... was it that they got hooked on stumps? *Hope you can shed some light.*
   / L3560 with BH 92 and AG's #5
I used an earlier model Kubota BH that required the 3 pt links to be removed. It was really not any big deal, even for this 71 year old galoot. Being totally realistic here... you're attaching and detaching a 2,000 lb backhoe to a 5,000 lb tractor. If you aren't being darn careful how you do it anyways, you probably shouldn't be messing around with such things, and 5 or 7 extra minutes to take the links off is trivial to the process.
   / L3560 with BH 92 and AG's #7
All I know for sure is that my lower lift arms come OFF before attaching my Kubota BH92 on my L5060.
That BH92 is one powerful digging attachment. ;)
   / L3560 with BH 92 and AG's #8
Kubota | BH92
I would think the subframe mount on a M6060 or L6060 would be higher off the ground than the L3560 right? Just keep in mind that is 100" is at the mounting point only, so if your machine has more clearance it will add to the overall height you are considering for a garage overhang, etc.
   / L3560 with BH 92 and AG's #9
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2239 (A51244)
2239 (A51244)
Hyster H225E (A47384)
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
1273 (A50490)
1273 (A50490)
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
