I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back?
   / I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back? #1
ilookonest
Croswell, MI
ford 1620
I bent my pull arm on my ford 1720 3-point hitch. Not much about 1 1/2 inch in to the center. It's still flat, just takes a turn to the left. I had a 3-point back hoe on it that I had just got, and I must have put some side pressure on it or something. But when I took it off after the first time I used it, I saw that I bent my right side pull arm on the 3 point. Now I'm building an underframe for the hoe, so it won't happen again. But I still want to straighten the 3-point arm. How should I bend it back? That steel is realy hard and I'm wondering if I should press it back to straight cold or if it would work better if I heat it up. If I heat it up will I have to re- temper the steel? If so, how would I do the tempering? I'm looking for some input and opinions on this.
   / I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back? #2
I bent my 3pt lift arm a few inches from straight. I used a log splitter with something covering the sharp edge. Then I used a 5" angle iron I had laying around to use as a backstop to push against. Could have used a 4' 8x8 timber. Worked like a charm.
   / I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back? #3
Bend it cold.
   / I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back? #4
I bent one arm on my 1920.
Just pressed it out straight .... cold.
Bought a new one just to be sure (they are not expensive).
I have a sub frame mounted 10' hoe on a 3400 Ford, but would never consider using a 3pt hitch hoe.
An easy way to rip out the tractor top link attach point.
   / I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back? #5
Just find something heavy and get a 20 or so jack ton jack. That's what I did any hoo.
gg
   / I bent my pull arm on my ford 1720 3 point hitch. How can I bend it back? #6
Find somebody with a shop press.
Ya, I'm getting the idea that I should bend it back cold. I can do that. I have a twenty ton shop press and a log splitter. And now that I'v done some research, I'm building a sub frame to mount the hoe to it and then attach it to my tractor. I'm also cutting the bucket narrower too. Thanks to everyone that replied.
Oh Man. That's exactly what I did to Mine too. I don't have a dozer but I do have that exact same 20 ton jack and a press. I wasn't sure if it should be heated or not. Thanks for the feed back.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
2001 Sterling Acterra Dump Truck (A50514)
2001 Sterling...
Husky Tandem Tank Spreader (A50774)
Husky Tandem Tank...
UNUSED MOWER KING SSFFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
2012 Chevrolet Cruze Sedan (A50324)
2012 Chevrolet...
Kubota R520S (A50120)
