Tire Selection Iseki TS3110 ag tire specs swapping from turf tires
   / Iseki TS3110 ag tire specs swapping from turf tires #1
Alexsprout
Iseki TS1910
Hi I currently have 6 stud 500 - 22 404 turf tires on the rear of my 4wd TS3110 and looking to put a set of ag tires on them, what would work? Been told that using the wrong size one could damage the 4wd but can't find out what they should be swapped for. Would need the new rims and tires.
Thanks
Alex
   / Iseki TS3110 ag tire specs swapping from turf tires #2
One place to look would be Tractor Data www. Titan makes a lot of ag. tires. If you don't have any luck on TD, contact Titan and tell them what you have and what you want to do. Get the numbers and contact your local Titan dealer who can order them for you and shipping is/should be free if you are patient and wait for a Titan delivery to his store....besides he can get you a much lower price than mfgr. list. BTDT Or ask him and let him contact Titan....may be easier to get a faster reply coming from a dealer, but dealer may be too busy to do all that leg work....just depends.
   / Iseki TS3110 ag tire specs swapping from turf tires #3
A little online search indicates the TS3110 is basically a White 2-30/ 2-35 crossover. AGCO Parts Books lists the 2-30/2-35 4WD models as front 6.00-16 AG tires on 4.5-16 rims, Rear 12.4-24 AG tires on 10-24 rims.
   / Iseki TS3110 ag tire specs swapping from turf tires #4
That should be easy enough to come up with. If the OP can't find someone local to help they can check with someone like Tucker Tire that does internet sales of tire packages. They were slightly less expensive than the local guys, but also had the rims and tires I needed in stock (already mounted on Titan rims in my case). I had them on the dock at work in two days. There are several companies around the country that do that sort of thing. As mentioned earlier, finding a Titan dealer either locally or online is the way to go.
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
UNUSED FUTURE VB59 59" HYD VIBRATING BUCKET (A58376)
UNUSED FUTURE VB59...
(3) SAFETY CONES (4) PIECES OF 3" PIPE (A58376)
(3) SAFETY CONES...
2021 Polaris Ranger Electric Utility Cart (A56857)
2021 Polaris...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
2008 John Deere 310SJ TC Backhoe, 4x4, 4n1 Bucket, extendable, Joystick. (A59213)
2008 John Deere...
