A clutch question
   / A clutch question #11
Did you get the 3/4 inch play that they mention in the manual. Im interested in how you did adjustment too
   / A clutch question
I adjusted the fee travel some to give it the inch of free travel.
   / A clutch question #13
Did you make the effective length of the threaded rod shorter or longer?
   / A clutch question
I think I made the threaded rod longer. Which ever I did the free travel did get a little longer but still seems to have the same issues
   / A clutch question #15
Thanks Scott. That's what worked for me, but I got to the end of the rod with only a little improvement.
   / A clutch question #16
Sounds like a clogged fuel filter or some other obstruction in the fuel supply.
I latched onto your first post and terms like “bogged down” and “sluggish” when I suggested the fuel issue.
From your later post it definitely seems as though something is slipping since you aren’t experiencing an RPM drop. If you do keep the RPMs up and the machine in gear one would think you would smell the clutch slipping and or see and feel signs of heat and or smoke at some point. Have you noticed any of these things?
   / A clutch question
There is a smell similar to when brakes get hot.
   / A clutch question #20
Sure sounds like a clutch problem. Do notice any smell like a clutch burning ?
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
15 FT Trailer (A50322)
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
KMC 3360 4-row Basket Dump Peanut Combine (A52128)
KMC 3360 4-row...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
