MF135 lighting inverter fail
   / MF135 lighting inverter fail #1
Rob Laughton
Ontario Can
MF 135 Gas
Hello folks,
I was getting my snowblower on, and checking everything over before our first big storm, and suddenly the lights went out.
No power from the inverter box.
The lights seem to run fine if I run another wire straight to the light switch. Can I leave it like this?
Why the inverter anyway...something about neon lights?
Thanks,
Rob
   / MF135 lighting inverter fail #2
Is your outfit fitted with neon lights? If so, they are likely the reason for the need for 120VAC and a suedo sinewave inverter. Inverters are by nature power hungry and waste a lot of energy. They can also be a danger if not wired and protected properly. I have no knowledge of the electrical circuits on your machine and so cannot comment.
An alternative you might consider...LEDs are cheap, they consume little power for the light they produce and will run happily off the 12VDC system you have on your M-F.
I have added a 12 VDC cigarette lighter socket and LEDs at the rear of my M-F so I can run a 12VDC AG pump for spraying and LED lights to the rear of the tractor for work at night. I also installed a fuse panel to protect the electrical system. If you are interested, I can give you the list of components I have used.
If you do add 12 VDC LEDs etc. to your machine, do the wiring correctly and resist the temptation to just hook up wires to the battery. It is dangerous and can start a fire especially on a gasoline powered machine.
   / MF135 lighting inverter fail #3
Also most LEDS like correct polarity when wiring up... Get them backwards they usually do not work....
Dale
   / MF135 lighting inverter fail #4
Hello folks,
Thanks,
Rob
NEON???........ Are you sure they are not HID (High Intensity Discharge)....
Dale
   / MF135 lighting inverter fail #5
Dale
An invertor is not necessary for HIDs. Many of today's automobiles are HID equipped. Heck, my BMW R1150GS motorcycle has HID in the low beam. Come to think of it, the OP may be incorrectly identifying the HID ballast as an inverter...Is this so?
How about a photo of your "inverter".
For low cost, low power consumption, high Lumen lighting, LEDs are the way to go.
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
Husqvarna Z 248F 48in Zero Turn Commercial Mower (A55851)
Husqvarna Z 248F...
UNUSED FUTURE DEER SHAPED SHOOTING TARGET (A57193)
UNUSED FUTURE DEER...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
