Trouble Shooting Emax 22 HP - Electrical issue
   / Trouble Shooting Emax 22 HP - Electrical issue
Update - The dealer sent a mechanic out to look at the tractor. The mechanic jumped the fuse and started the tractor. This caused the wiring harness behind the instrument panel to smoke according to my friend. So they are replacing the wiring harness. I believe he said there are two of them.
Hopefully this takes care of the issue as he has had the tractor in the shop 3 or 4 times in the couple months he owned it. Thankfully the dealer has been very good.
2 main spots this will happen... behind the ECU the wires of the harness make a hard bend and will rub against the metal.. you wont be able to see it until you get a look at the back side of the wires which means taking apart a lot of stuff. Another is the wires for the front headlight can be loose and getting pinched when the hood is closed it wont tear and is very hard to see the exposed wire but I fought one for days until I found this issue... can always check the wires under the seat also for the safety switch being pinched when someone sits down as well
Thanks for info
   / Trouble Shooting Emax 22 HP - Electrical issue #13
the "Mechanic" must be a total Noob, you NEVER jump a fuse:eek: hopefully he learned his lesson..
Jumped it with a screw driver :confused3:
Update - both wiring harnesses were replaced. Machine was run today for 5 hours without issue.
   / Trouble Shooting Emax 22 HP - Electrical issue #17
Smoke test is usually a last resort. Have to be willing to replace the most expensive piece of equipment in the circuit. Wiring harnesses arent cheap i dont imagine. Could have meggered or hi-pot tested individual conductors but sounds like you got what you needed fixed
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52128)
2023 Maxx-D TDX...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
2009 Hartland Camper (A50514)
2009 Hartland...
Zero Turn Mower (A48082)
Zero Turn Mower...
