Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I don't know first things about them (nice brand, trash brand...)
Have an International 1066 that has a MCV valve on it. I want to test some of the pressures on it.
Any brands to go towards and stay away from??
The IH should be standard size threads. I also have a JCB backhoe that has (I"m told) "British" metric....so if the gauge would do both, all the better.
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #2
Just about any glycerine filled gauge you will find will have 1/4 NPT male threads. You will need a high pressure hose to adapt from that to something like -4 JIC female then adapters to fit whatever you are testing. Consider a hose up to 6 longer or more so that you may observe the gauge from the operators seat of the machine. You will need a gauge that reads in the 0-1000 psi range for low pressure testing (MCV circuits) and another in the range of 0-5000 psi for hydraulic function circuits. Gauge brand is not critical.
I thought I read somewhere that the PSI numbers should be under 400 therefore, my interpretation was a lower PSI reading would be better (higher resolution)
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #4
Your choice. The next time you need a lower pressure gauge the spec might be closer to 500 and your safety margin disappears. A 500 psi gauge would work on the IH.
Edit: ASTM standards suggest observed values should fall between 25% and 75% of the gauge range. A 1000 psi, 500 psi or 600 psi gauge should perform satisfactorily to measure MCV pressure. Lube pressure would require a lower pressure gauge to measure accurately.
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #5
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #6
Um, my system bypass valve is set at 2,100 PSI (or there about on my MF at pump body) .. I would think a 400 psi system probably does not have much work ability....
Dale
It is regulated circuit pressure for clutch packs.
Not knowing much about this, I'm suspecting I was getting this confused with the other.
So, to help my ignorance.... have any brand suggestions? (prefer to stay away from China if that's possible anymore)
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #9
I can’t advise you on that because every time I have bought gauges I’ve bought on price and have yet to be disappointed. Spend as much or as little as you feel comfortable with.
   / Suggestions for hydraulic gauge (for diagnostic purposes) I think at/under 400 psi #10
I try and get a gauge where it will read in the middle for my anticipated reading. If I expect to see 500psi I would want a 1000psi gauge. As RickB said they are most accurate in the middle 25% -75% of their range.
2015 WESTERN STAR 4900 SF (GLIDER) DAY CAB (A53843)
2015 WESTERN STAR...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2014 Chevrolet Tahoe 4x4 SUV (A52377)
2014 Chevrolet...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
