Ballast Will Deere 1025R rear wheel weights fit the GC17## rear wheels?
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #1
nhwylee
Bobcat CT2035
Has any fitted Deere 1025R rear wheel weights to GC1705, GC1710, GC1715, or GC1720 rear wheels?
Obviously holes would need to be drilled but I'm curious if the weight outside diameter was close enough to the wheel inside diameter not put all the stress on the center hub. If no one has attempted it, maybe I'll have to be the guinea pig.
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #2
Almost Any 12" wheel weight will fit . You may have to get a different length carriage bolts . And as you said massey will need holes drilled .
I have used all sorts of variations thru the years .
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #3
I'm puzzled by your question.
With most weights the first weight bolts to the wheel center and the subsequent weights
are bolted to the first.
So yes actually the center disc supports all the weights.
In this picture the first weight is bolted to the rim center and the second is bolted to the first.
Regular hex bolts are used to secure these weights, they are 300# each.
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #4
Another option is get your tires filled with rim guard or similar to give you the weight needed or use your 3 point hitch weight box
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #5
I went with ballast box (between 500-600 pounds) as I only need weight when picking up heavy stuff with FEL...
Dale
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #6
Dale
My tires are loaded and I have a weight box, if I were to do it again I would follow you're lead..
   / Will Deere 1025R rear wheel weights fit the GC17## rear wheels? #7
Have been having some thought about wheel spacers though... Been thinking a but wider track on rear would help stability.....
Need to take some pics of ballast box and post them up, maybe tomorrow if not raining....
Dale
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
John Deere 6120E (A50323)
John Deere 6120E...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
