MF35 broken starter and snowed in!
   / MF35 broken starter and snowed in!
It was not bad. First, disconnect the ground from the battery then the hot wire from the starter. Next loosen the hose fitting where it connects to the PS but I did not have to disconnect it completely, just loosen it enough so it can move a bit. Pull the two starter bolts and wiggle the starter out of there. It's a minor pain but nothing serious.
Is the bendix the thing that pushes the starter drive gear out into the flywheel teeth? If so, that's the part I replaced on mine. It was not very difficult.
How big is your snowblower? I've been looking at snow blowers on CL but wasn't sure how wide a unit the tractor can handle.
   / MF35 broken starter and snowed in! #12
Nice, seems easy enough. Yep, the bendix is what kicks the starter gear out to engage the flywheel. I figured it wouldn’t be too bad. Just wasn’t sure if the distributor needed to be removed. I don’t feel like re-timing if I can help it, machine runs awesome right now.
My snowblower is a 6’ McKee Sno-lander 520. As long as your machine runs well and the governor is properly adjusted (very important), it’ll handle a 6’ blower no problem as far as power.
Does your machine have the shuttle shift? (Geared reverser). If so, that’ll help a lot because you can move pretty slowly in reverse. I have the shuttle, so I’m not sure how fast reverse is without it.
With the shuttle, you have reverse in first, second, and third for both hi and lo gears. That being said, for light fluffy snow I can hit up to 6” in 2nd low reverse and it’s not too fast. Real deep or wet heavy I use 1st reverse low.
My blower has a three blade fan in it, 24”. I keep reading that a four blade fan is better but I’ve had no issues. I plan to make an impeller kit for it, as it’s old and there’s a decent gap between the fan and housing. It’ll throw further with the gap closed, but as of now it throws 20ft no problem.
My snowblower is a 6 McKee Sno-lander 520. As long as your machine runs well and the governor is properly adjusted (very important), it handle a 6 blower no problem as far as power.
It sounds like a 6' blower is about all the tractor could run, and a 7' or 8' would be too much. Am I reading you right?
Does your machine have the shuttle shift? (Geared reverser). If so, that値l help a lot because you can move pretty slowly in reverse. I have the shuttle, so I'm not sure how fast reverse is without it.
Yep I have shuttle shift, so gears 1, 2 and 3 are available to me in reverse.
I'm going to keep my eyes open on auctions around here this summer and see if I can't find a deal. We normally don't get THAT much snow that a blower is necessary, but there are times when it would sure be nice.
   / MF35 broken starter and snowed in! #14
Yep, you got it. General rule of thumb is about 1 PTO HP/ft of blower (same goes for flail mower). If we had a hydrostatic tractor we could REALLY slow our travel speed and keep RPM up to use a larger blower.
I’m the same, we usually don’t get that much snow, but we’ve had a few storms that even with loaded tires, chains, cast wheel weights, AND the 550lb blower on the back i STILL couldn’t get enough traction to move the snow. The blower alleviates that problem.
1st low reverse, RPM pushing 540@PTO, and just chug along through it. Especially useful at the mailbox where the state plow dumps often 4’ of snow about 5’ wide in big storms. I just blow it up the bank. If I plow it, you can’t see pulling out of the driveway. So it’s either blow it away, or remove the plow and bucket it all up onto my property somewhere. That’s too time consuming.
I don’t use it all the time, but the times I do make it well worth it. I can’t remember whether I paid $500 for it or $800. I *think* it was $500.
The guy I bought it from had too fast of a reverse gear to run it in deeper snow, got tired of working the clutch all the time.
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
378721 (A54865)
378721 (A54865)
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
