Hydraulic oil leaking from pto lever
   / Hydraulic oil leaking from pto lever #1
Dabrowski
Member
Melb, Australia
Massey Ferguson 35
Hi guys.
Does anyone know the procedure for replacing the rubber oring behind the pto selector? Do I need to drop the oil? Can I replace it without removing the cover plate? Should it be set to neutral, ground speed or engine speed if removing the plate?
I used to have a leak behind the cover plate & 6 screws in the photo but that's been fixed by a new gasket. IMG_20190218_212724.jpeg
   / Hydraulic oil leaking from pto lever #2
Hi guys.
I used to have a leak behind the cover plate & 6 screws in the photo but that's been fixed by a new gasket. View attachment 594691
Hi, you must drop the oil through the drain plug and then remove the cover of the PTO lever, no matter what position it is in (ground - neutral - motor) just remember it when you replace the cover, take advantage of cleaning the Hydraulic oil filter, after assembling test with the engine off the positions of the lever to be sure that everything went well, a greeting from Uruguay.
   / Hydraulic oil leaking from pto lever #3
You don’t have to drain all the oil out, just below the level of the lowest bolt. Just top it off after you’re done. That whole assembly must be removed if I remember right. There’s a roll pin on the front side along with a spring and detent on the back side. Pops apart pretty quickly, but if you remove the roll pin with that plate installed, the selector, spring, etc will fall into the transmission sump.
When I did mine, I just removed the plate and let the oil run out into a pan. Then I just put fresh oil back in and recycled the bit that came out. If you remove the lowest bolts last, you can prevent too much oil loss. Put the bolts back in after the plate is out to slow the loss of oil, too.
Could I just jack up the left side so that would prevent oil from coming out of the cover plate?
   / Hydraulic oil leaking from pto lever #5
Doubt it, but honestly I’d just pull the bolts out and put a drain pan under it- whatever drains out you can catch and recycle. Just top it off when you’re done. No big deal really, if you’re quick to put the bolts back in you won’t lose much oil at all.
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A53472)
2009 Ford F-650 24...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
JOHN DEERE LOT IDENTIFIER 111 (A53084)
JOHN DEERE LOT...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
