Hydraulic hoses are difficult to re-connect
   / Hydraulic hoses are difficult to re-connect #11
   / Hydraulic hoses are difficult to re-connect #12
My goal is to leave this world just like I came into it. BROKE...
Wedge
   / Hydraulic hoses are difficult to re-connect #13
I've loosened the quick connector with a wrench to relieve the pressure, worked in my case as it was really locked up.
joel
   / Hydraulic hoses are difficult to re-connect #14
After disconnecting I just press the male tip and bleed a teaspoon or so amt of fluid into a catch container. This leaves enuf expansion room so pressure doesnt build up.
larry
   / Hydraulic hoses are difficult to re-connect #15
   / Hydraulic hoses are difficult to re-connect #16
Some where there was discussion on making a simple "U" shaped bracket with a nut welded to it and a bolt to press on ball (sort of like "C" clamp)... The DIY clamp has a spread base that goes around the coupler near lower end where threads are and the screw is long enough to thread down and put a bit of pressure on ball to relieve pressure...
OR you could do something like this... Actually modified QC...
Dale
   / Hydraulic hoses are difficult to re-connect #17
Those modified couplers would be nice to have. Does any body sell those?
   / Hydraulic hoses are difficult to re-connect #19
For some reason, I don't have this problem.
Before I disconnect the QC's I shut off the tractor and work all the hydraulic levers back and forth to relieve line pressure.
When I do disconnect, I only get a little weep of fluid and not under pressure.
   / Hydraulic hoses are difficult to re-connect #20
I do one extra step. After disconnect from the tractor supply, I reconnect the hoses to each other on the grapple side. and disconnect , and a bit more fluid will weep out. This leaves a "deficit" of fluid in the hoses. Then I connect the hoses to each other. Then even if temp changes or implement relaxes just a bit, since there is a deficit of fluid in the hoses, and pressure never builds. I NEVER have difficulty connecting hoses with this method. The other advantage is now the hoses are connected to each other and dirt/water cannot get in.
KUBOTA RTVX900 (A51243)
KUBOTA RTVX900...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
10855 Pumping Unit- ENGINE ONLY (A52128)
10855 Pumping...
2014 CATERPILLAR 279D SKID STEER (A51242)
2014 CATERPILLAR...
EZGO (A50324)
EZGO (A50324)
