PILOON
Super Star Member
Just tap the little ball at the end of the male and 'burp' that side to relief pressure built up.
On the female coupler you can either temporarily do an 'almost' reconnect so as to burp that side, that, or use a ,say, 3/8 bolt and depress the recessed little ball inside.
Those 'burps' will simply result in a teaspoon or so of fluid loss but make connecting much easier.
Also cycling the circuit valves after shut down greatly helps to equalize the pressures.
