new member
   / new member #1
hillbilly53
mellen, wi.
1958 ford powermaster 841
Hello to all, trying to get a 1958 Powermaster up & running. Tractor runs like new, having problems with the hydraulic system. I drained & flushed the case out, rebuilt the hyd pump also. Pump is primed & flows fluid out of the pump but no pressure at pump. No hydraulic lift at all no matter how I move the draft or position levers. Anyone have a suggestion or what to do NEXT?? The tractor had set outside in the weather for a few years without being used or ran.
Thanks
Hillbilly 53
   / new member #2
:welcome: :tractor:
Welcome to the forum!
I'm going to move this thread over to our vintage Ford section to see if we can find you some advice.
   / new member #4
:welcome: to TBN...enjoy.
   / new member #5
HillBilly53- Welcome to TBN!!! And good luck.
   / new member #6
Can't help with the hydraulics but can say :welcome: to the forum.
   / new member #7
Welcome to the forum.
   / new member #8
Thanks
Hillbilly 53
Where are you checking pressure from the pump? If you have fluid coming from the hex bleed screw on the top of the pump, the pump is moving fluid and should be building pressure. Per the attached troubleshooting diagram from the service manual, check the flow control valve. 20190429_210452.jpg20190429_211749.jpg
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2018 Hino 155 16FT Cab and Chassis Truck (A51692)
2018 Hino 155 16FT...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
