No Excavator, No Problem Kubota GL4060 + SawZall
   / No Excavator, No Problem Kubota GL4060 + SawZall #11
   / No Excavator, No Problem Kubota GL4060 + SawZall #12
Good job on the tap roots.
Cut many a root, limb, or small tree trunk with my Craftsman C3 reciprocal saw. I can cut almost anything from trees to channel iron with the right blade.
I've done something similar, but found that the Porter Cable pruning blades work a lot better. My wife loves using them around the yard to prune trees, and I use them all the time to cut roots when trenching or digging footings.
https://www.amazon.com/PORTER-CABLE...way&sprefix=porter+cable+sawz,aps,1058&sr=8-4
Hi Eddie, I am gonna give this Porter Cable blade a shot. They look VERY aggressive and have the same fitting as my Milwaukee blades so should work. I will let everyone know how it goes. Thank you so much!
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A56857)
2025 GIYI GY-PG72C...
Riding Mower (A59231)
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR7DDBZ7653 (A57453)
2013 Freightliner...
Towable Diesel Generator (A59228)
Towable Diesel...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
HYD PUMP & TANK SET (A58376)
HYD PUMP & TANK...
