Which Side Of The Impeller, Does It Matter?
   / Which Side Of The Impeller, Does It Matter? #1
Chaos USMC
South Central Pennsylvania
TYM T503, 1962 Case 530 Case-a-matic
My snowblower barely throws anymore. I have a roughly one inch gap between the edges of my Woods SS74 PTO driven snow blower impeller blades and the barrel. Getting ready to mount some conveyor belt "flaps" to close up that gap. To achieve the best performance and to prevent any form of clogging, any experience dictate which side of the impeller blade the flap should be mounted? Does it matter?
On another note, the SS74 is a fairly old beast, has anyone ever upgraded the impeller itself to a newer generation model; instead of putting flaps on?
Thanks in advance.
   / Which Side Of The Impeller, Does It Matter? #2
i had a blower that the flaps were slowly over time bent back on the impeller, may want to see if they are still pointing the correct direction.
   / Which Side Of The Impeller, Does It Matter? #3
Interesting question. I don't have personal experience, but seems the difference would be where the flap can pivot/flex. On the front side it can only flex in gap below the impeller, on the back side it would have the additional distance to flex up to the bolt you used to mount it. What is this distance? How flexible is mat?
For me the answer on which side to mount would be how perfectly round is the housing? Is there any rub? Do you need it to flex at one spot because it's not perfectly round housing? Do you want some flex for that occasional piece of gravel or stone?
If you don't want it to flex, why not put it on front for max. stiffness and tightness?
In the end, it probably doesn't matter that much one way or another.
   / Which Side Of The Impeller, Does It Matter? #4
It will be better supported & stiffer on the front side of the blade. More likely to tear out on the back side, even if fender washers are used.
   / Which Side Of The Impeller, Does It Matter? #5
Thanks in advance.
If the 2nd stage impeller paddles/impeller vanes are not bent back from impact damage the issue is moot as using conveyor belt to reduce the clearances will only work temporarily for you as the conveyor belt is not stiff enough to resist the impact damage.
The design of the American made and some Canadian made snow blowers is very poor in that the 2nd stage impeller paddles/impeller vanes do not have close clearances to the impeller housing and as a result the snow will build up and melt from the friction caused by the rotation of the impeller within the impeller housing and a ring of ice/slush forms and the end result is that the impeller is unable to clear the ice/slush ring.
You should check with your implement dealer to see if they offer an improved 2nd stage impeller with longer vanes/paddles to take up the space in the old impeller housing.
I would be more concerned with your being able to remove the impeller to install the wipers. The issue is going to be removing the impeller from the gearbox shaft extension as you will need to heat it for a long period of time to break the rust bonds on the impeller housings shaft bore and the shear key. It may be easier to rent an ice melting machine for water pipes to create the heat needed to break the rust bonds as smoke wrenches and old paint do not mix and the fumes are very toxic.
I will tell you that you need to either invest in a snow blower impeller kit for your 3 point hitch snow blower as it will be easier to mount the hard rubber flaps and the sheet metal plates that hold the hard rubber in place.
By using the softer rubber belting for round baling machines or old conveyor belt your going to see that it will not last as long and will be of little help over time as it is designed to bend and roll over large and small diameter conveyor pulleys and it will essentially become a weak snow broom.
You could purchase a small stall mat from tractor supply and do your own cutting using a very sharp carpet knife for the number of pieces you need for the impeller and then make use of a drill press to drill the mounting holes and a vise to drill the mounting holes in the impeller paddles; BUT, if you purchase an impeller kit for 3 point hitch snow blowers 90% of the work has all ready been done.
You just have to measure the inside diameter of the impeller housing and then you can measure and mark the mounting holes for the sheet metal plates that will hold the hard rubber pieces as the kits will have two sheet metal plates for each impeller paddle/impeller vane and also nylock nuts to hold the assembly in place on each impeller paddle/impeller vane.
If you decide to make your own impeller paddle/impeller vane wipers using a heavy cow stall mat you need to keep in mind that you will need 2 pieces of strap iron or heavy sheet metal(strap iron is preferred simply because you have a bigger 2 stage snow caster and you need either coarse thread nylock nuts and bolts or fine thread bolts and nylock nuts and flat washers for the nut side of each bolt.
The piece of hard rubber must be mounted on the top of the impeller paddle not the bottom.
When you look at the snow blower after you have the cross augers and the gearbox keep in mind that as you look inside the impeller housing you need to mark the top portion of the impeller paddle/impeller vane with a T before you remove it.
This is so you will be fully aware of where the rubber wiper must be located as the top portion of the paddle/vane is where the impact occurs before the snow is ejected through the chute and the steel or sheet metal plate holding the rubber mat prevents it from becoming torn from the impact AS LONG AS the bolts and nuts are properly torqued down. In saying that it is better to use fine threaded nuts and bolts as they have more gripping surface and ability to hold the rubber wiper and steel/sheet metal plate in place.
You could do this by removing the chute and spout but you will need long drill bits and lumber to hold the impeller in place while you do this but if you can remove it and put it in a vice you can clamp the sheet metal in place with vise grips and drill the holes using the dewalt 2 point metal bits which eliminates the need for a pilot hole as long as you have oil to lubricate the bits as they drill.
Be sure to wipe all the oil off or use alcohol to clean the metal completely as any leftover oil on the metal will cause issues with degrading the rubber.
   / Which Side Of The Impeller, Does It Matter? #6
A 1" gap is a lot so if you go with rubber belting put it on the front side of the blade so it is somewhat supported.
You might look at using steel though. Use 3/8" mild steel that is the width of the impeller blade. If you have a 1" gap you should make your extensions about 3" long or longer so it is supporting the end of the impeller blade. Put those extensions on the back side of the impeller blades if possible. Tack them in place while the impeller is in the blower, then remove the impeller to finish welding them in place.
I had a McKee blower years ago. It had a big gap but the gap was mainly caused by the impeller housing being worn out, it even had holes in it. I relined the housing with some thin wall pipe which took care of the gap. The point is, if your housing is worn out, fix that first.
   / Which Side Of The Impeller, Does It Matter? #7
Interesting situation. From about 1987 until 2009 I had and used a 3-point snow blower. It was called - The Blue Machine. The company went out of business around the year 2000. In those twenty plus years of use I never had problems with the impeller wearing out.
Makes me wonder. Was the impeller on my Blue Machine made of superior materials. Are you guys blowing a lot of sand & gravel. Do the more modern snow blowers simply have a built in greater clearance.
I, most certainly, wore the blue paint off the impeller. But it never went any further than that. I'll bet that the impeller was much "tighter fitting" than the more modern ones. I really can't believe that simple snow would wear out the metal on an impeller.
The impeller on the Blue Machine was steel. Not aluminum or plastic.
Outstanding input and comments from all of you who have responded thus far. I thank you for taking the time and appreciate your efforts to put your thoughts down on "paper". There is obviously a lot more to think about beyond simply bolting "some kind of material" onto the impeller. Never thought of relining the housing and will have to check that out tomorrow. Another great point mentioned an impeller kit; who would have thought... Heating the impeller shaft; great advise and something I did not anticipate either, makes total sense of course.
Maybe I'll just sell the beast and put the cash towards a new one! ;-)
   / Which Side Of The Impeller, Does It Matter? #9
The McKee blower I mentioned was an old blower when it was given to me. It was at least 25 to 30 years old and had cleared a mile long gravel drive when since it was new so it had a lot of gravel through it. All that gravel is what wore out the impeller housing. I doubt much had been worn off the impeller itself.
   / Which Side Of The Impeller, Does It Matter? #10
Since its "slowed down over time" I'd sure like to see photos of the impellers and its gaps.
206320 (A57192)
206320 (A57192)
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
