Kubota Zero Turn Starting Issue Z125S
/ Kubota Zero Turn Starting Issue Z125S #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
When I go to start this machine I have the battery fully charged and all it does is groan. I thought it was the battery so I put in a new one this morning and have the same issue.
I have proven all safety interlocks work to include control handles, parking brake, electric mower clutch, seat switch. The lights work too. I have isolated it to the click at the starter, and checked all fuses. Power goes to the starter but it won’t turn over. Any ideas please?
/ Kubota Zero Turn Starting Issue Z125S #2
clean both battery cable connections maybe w/baking soda? or proper cleaner. sandpaper also works well. disconnect the starter positive connection & do same. then look for all ground connections, remove & clean. std procedure as with any battery issues. best regards
good idea. OP: how many hrs?
Only 82. Had belt issues first two years it was at dealer more than here. Kubota stepped up and did the fix.
/ Kubota Zero Turn Starting Issue Z125S #6
then start off by cleaning battery/starter/ground connections. let us know, mowing season will be on us, but a while up in your area
just finished going through my own
as far as belts, if premature failure i recommend kevlar reinforced, big difference over stock replacement imho
Vbelts4less - Mower V Belts - V-Belts - Banded V Belts - Kevlar V Belts - Cogged V Belts - Industrial V Belts
Hey Bubba, thanks for the advice. I swear I will toss and turn all night thinking about this stupid thing. I know it will be a simple fix but still bugging me. Thanks to all on the site for your help, I will work on it tomorrow all according the weather.
/ Kubota Zero Turn Starting Issue Z125S #8
rest easy....while the grass grows :)
/ Kubota Zero Turn Starting Issue Z125S #10
Replace the starter solenoid. Had the same issue with my Z122R.
/ Kubota Zero Turn Starting Issue Z125S #11
Is it still within the 48 month warranty? At only 82 hours Kubota would have to fix it if it is under the 48 months.
/ Kubota Zero Turn Starting Issue Z125S #12
Does it start when you use a jumper wire on the solenoid?
Haven’t tried that yet, I’ll go out when it warms up later.
Have not thought of that, I will call them. Definitely within 48 months.
91D8DF91-4C4E-4DD1-947F-10080CA2354F.jpegFE6CCE33-B94C-46CD-88B6-337E41C8C9B6.jpegFrom the OP: I jumped the solenoid this morning and got the same groan. I took the thing apart to see what was up and I found the starter was broken, the starter shaft was broken in half. I don’t know what caused it but I have the dealer looking into it.
Oh, and the engine turns freely.
/ Kubota Zero Turn Starting Issue Z125S #16
Jumping off this aged thread. I'm having the same/similar starting issues. [Understand from Kubota dealer that this is common issue. Had it there a couple times; fixed, but when I asked what the problem is, dude can't remember]. When I Turn the key, sounds like the "PTO" clutch solenoid clicks, and nothing at the starter. Solenoid is new, starter is new, all contacts are clean, tested all the "safety" switches; all in order. I unhooked all wires to the starter, hooked on a remote starter directly from battery to starter, the engine barely turns over. Did the same with the big booster/charger on boost, same result. [Yes, starter was bench tested before i installed it to ensure it was not 'NEW' as in never-ever-worked]. That silly kohler should spin easily, especially off the booster/charger, right? Any thoughts?
/ Kubota Zero Turn Starting Issue Z125S #17
I am surprised it turned over. You said you disconnected all the wire from the starter. I am assuming you also disconnected the 12 volt battery source from the starter. Measure your battery voltage with a volt OHM meter. Does the battery test show readings greater than 12 volts?
Remove the wire coming from the ignition switch to the starter solenoid. Turn the ignition switch to on. Take a covered heavy duty 12 volt wire long enough to reach from the battery to the starter solenoid. Connect one end to the positive post. Remove the protective covering from about a 1/2 inch of the other end of the wire. Now touch the post on the starter solenoid, the one you remove the starter solenoid wire coming from the ignition switch. The unit should spin over and start. As soon as it starts remove the wire you were holding against the starter solenoid. Do not continue to hold the wire against the starter solenoid.
If jumping the solenoid starts the engine you are suffering the low voltage problem from the switch to the starter solenoid. Yes it is a common problem . You will need to install a 12 volt relay in your circuit coming from the switch to the starter.
/ Kubota Zero Turn Starting Issue Z125S #18
Appreciate the response. Yes, I removed all the hot from the starter and removed the ground from the starter bracket bolt as well. Then I bypassed the entire electrical system and used the remote starter device below. First from the battery [which tests 12.7v]. Starter engages and did not spin the engine. Second, from the HD battery charger in boost mode. Same result. Jumping does not start the engine. This thing has given me grief the past couple years. Based on what I've read, I planned on a 12v relay install. Right now, the engine does not spin. Just drags.
/ Kubota Zero Turn Starting Issue Z125S #19
View attachment 597476View attachment 597477From the OP: I jumped the solenoid this morning and got the same groan. I took the thing apart to see what was up and I found the starter was broken, the starter shaft was broken in half. I don’t know what caused it but I have the dealer looking into it.
Welcome to the Kohler Courage twin starter issue. The top bushing wears and gets oblong, and then gets to a point where it will bind with the flywheel, and then it breaks the shaft off. Replace the starter on move on. There is a way to upgrade to the Command series solenoid shift starter which eliminates most of the starter issues.
/ Kubota Zero Turn Starting Issue Z125S #20
I resolved the bushing issue with the original starter with a new starter yesterday. "Solenoid is new, starter is new"..... "Yes, starter was bench tested before i installed it to ensure it was not 'NEW' as in never-ever-worked"
Will the Kubota dealer know about this "upgrade to the Command series solenoid shift starter which eliminates most of the starter issues"
2022 CORMIDI C85 STAND-ON HI-TIP MINI DUMPER (A60429)
2022 CORMIDI C85...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
ALLISON TRANSMISSION (A55745)
ALLISON...
