Vertical Wood Pellets Smokers ??
   / Vertical Wood Pellets Smokers ??
Problem with smokers like this is that they don't put out enough heat to use in the winter. I like to smoke year round, in fact I probably smoke more in the winter.
Are you speaking from past experience smoking with this particular model smoker? It is double walled one would believe it would hold the heat in cold weather.
Smoking Ribs today.
   / Vertical Wood Pellets Smokers ?? #13
The electric one's will have a little trouble keeping heat in cold weather, and yes that is from experience. One of the main reason's I went with a higher quality Pellet Smoker. But for most the small electrics are fine and quite simple to use. My first electric started shocking me so it went bye bye and I went with the Pit Boss Pellet. But starting out, I would definitely recommend the electric's to anyone for their simplicity.
My smoker is wood pellet with electric to feed pellets.
   / Vertical Wood Pellets Smokers ?? #15
Nice, I did not realize that. I thought it was just electric.
   / Vertical Wood Pellets Smokers ?? #16
Awesome, might need to check one out.
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
