New water pump leaks
   / New water pump leaks #1
RoyK
North Central PA
NH TC29D
So I just replaced the water pump on my TC29D after removing radiator first. When I got it all back together and filled up, I ran it a bit and saw it had a slow leak. It seems to be leaking from the new pump gasket, a slow drip. I don't know if I didn't tighten it enough, the gasket got kinked, gasket quality, or what. Now I have to decide whether to tear the whole thing apart again and replace the gasket or just live with it and keep adding coolant as needed. Or could I try stop leak? I've always considered stuff like that as snake oil, and have never used it before. What would you guys do?
-Roy
   / New water pump leaks #3
It needs to be done right. Take it apart and redo it ! Just make sure the mating surfaces are clean with no debris.... Crisscross tighten all the bolts...keeps the flange from warping.
Does anybody know the torque settings for those bolts? I get real worried about over-tightening anything going into the block.
   / New water pump leaks #6
If you have an owners manual look in the front of the book. It should list the torque for all the different size bolts. If not use a torque chart off the internet or use the attached chart.
  • FastenerTorqueCharts.pdf
Well, lucky for me, things must have settled in. I had to run the tractor yesterday to rake out the devastation to my driveway from all the rain we had last summer and the winter and not a drop is leaking. Let's hope it stays that way.
   / New water pump leaks #8
Sometimes you just have to get gaskets moist and let them swell up!
   / New water pump leaks #9
Well, if it really was a leaky gasket they usually do not repair themselves...
2023 UNVERFERTH 632 LOT NUMBER 178 (A53084)
2023 UNVERFERTH...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
