Vertical Wood Pellets Smokers ??
   / Vertical Wood Pellets Smokers ?? #21
Are you speaking from past experience smoking with this particular model smoker? It is double walled one would believe it would hold the heat in cold weather.
Yes, I speak from experience. It's not so much the insulation as the raw amount of BTUs -- just not enough heat input for cold weather. And it doesn't matter if it's a gas unit or an electric, since you've got the equivalent of a one-burner grill (or less) either way. Generally I have to run about 3X to 4X the heat input to smoke stuff in the winter.
Keep an eye on the temperature as you head into cooler weather -- once it starts having problems keeping up then change your cooking technique, look for an alternative, or wait for warm weather. Nothing can ruin a nice piece of meat more than a cool cooking temperature. Pork cooked to 145-150F is perfect for slicing and carving. For pulling it needs to be at least 220F and is best at 250F (fall off the bone). In between, from about 155F-210F is a zone where the meat is just not going to be good eating -- too tough and stringy. Avoid that temperature zone!!
The one listed for $600?
$600 was the on line price here also we went to our local Costco in ann arbor mi. and the same unit was $449.Must be a regional thing I guess.
   / Vertical Wood Pellets Smokers ?? #23
My motorcycle riding buddy had a Traeger. It was horizontal and used "flavored" pellets. It certainly got hot enough to smoke and cook anything.
   / Vertical Wood Pellets Smokers ?? #24
I will go check one out. Showed the wife, she didnt say no. Lol
I got a costco rebate check burning a hole in my wallet.
   / Vertical Wood Pellets Smokers ?? #25
We roast pigs at 250, it falls off the bone.
   / Vertical Wood Pellets Smokers ?? #26
No smokers at costco tonight, except the louisiana egg.
   / Vertical Wood Pellets Smokers ?? #28
I pretty much cook everything I cook on the BGE at 250. Ribs, pork roasts, brisket, etc. I have cooked a couple cowboy steaks, and I sear them at high heat, but crank it down to cook it. One thing I learned, though, about brisket...buy the best grade you can get; prime if you can get it, nothing less than choice.
   / Vertical Wood Pellets Smokers ?? #29
BGE around here is Baltimore Gas Electric. I guess you don’t mean them.
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2021 Doyle 8 Ton Trailer Tender (A52128)
2021 Doyle 8 Ton...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
