countrybumpkin
Elite Member
- Joined
- Jun 14, 2005
- Messages
- 3,237
- Tractor
- Kioti, kubota
hmm interesting - I am not sure why you wanted to compare this to fluid film? fluid film has lanolin. does your can shows whats its made with?
Couple of cans of a similar product followed me home from work one day. Great stuff like you said, it'll creep then thicken up into grease.........Mike......sprayable fluid that shortly later thickened into a grease consistency. I loved it because you could spray it, flow/run it and know that once it crept in to the gaps of moving parts and had 5 minutes or so to evaporate the carrier.
What was it? Is it available retail or is it a professional only product like ZEP?Couple of cans of a similar product followed me home from work one day. Great stuff like you said, it'll creep then thicken up into grease.........Mike
Can't remember the name, it was a consumer grade product...I think. Only thing I remember is it was called Spray Gel-Lube and it had a paper label because it fell off and I had to write the name on it. Spraying it had the viscosity of water and once the carrier evaporated it was sticky and as thick as white grease........MikeWhat was it?
I might want that gel. Let me know what it is like. I have had aerosol cans before that were a sprayable fluid that shortly later thickened into a grease consistency. I loved it because you could spray it, flow/run it and know that once it crept in to the gaps of moving parts and had 5 minutes or so to evaporate the carrier... it thickened up into a nice grease like lube that worked way better than WD-40 alone.
So, please do share your opinion of that "gel". I bet others will have similar interest in it as I do.
