New Holland 555E Hydraulic pump stalling motor on start up?
   / New Holland 555E Hydraulic pump stalling motor on start up? #1
Rusty Rudder
New Holland 555E
If this has been discussed, please forgive and direct me to the thread, thanks in advance !
Purchased my '99 NH 555E recently with 6000 hours. All was well for the first 15 hours.
Now, the engine will not start unless I am deflecting one of the loader valves, up/down/bucket.... engine starts. Let off on the bucket control lever and engine is stalled by what sounds like the hydraulic pump deadheading.
I can keep it running by actuating the loader controls and raising the rpm's and the engine will continue to run even after letting off on the bucket controls but, the engine labors to continue to run. (While operating like this I loose steering hydraulics occasionally ....)
I am wondering what component would or could most likely cause this and where it is located ?
   / New Holland 555E Hydraulic pump stalling motor on start up? #2
One of the stabilizer controls isn't stuck in the up position is it ?
   / New Holland 555E Hydraulic pump stalling motor on start up? #3
Try operating all the controls on the loader, backhoe, and stabilizers to see if any feel stuck.
I'll check ! I was in a muddy quagmire of a mess, stuck, using every control I had to get out... Something could have stuck and I did not realize it. thanks !
Back from the shop, none of the controls are stuck, all in natural
position and move freely....
   / New Holland 555E Hydraulic pump stalling motor on start up? #6
Sent you a link through PM. Use the download option near top right to save to your computer.
   / New Holland 555E Hydraulic pump stalling motor on start up? #7
It would be good not to run your machine with the pump being dead headed .
Agreed, I have only run it to test the changes I am making work or do not work, brief operation at best...
Leaning toward a stuck rear pump main relief unload valve ?!?
   / New Holland 555E Hydraulic pump stalling motor on start up? #9
How about an improperly seated quick connector? If you have them suggest you re-seat them.
Dave M7040
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
