My fist impressions of my new eMax 22 HST w/ loader
   / My fist impressions of my new eMax 22 HST w/ loader #1
cmore
Gold Member
nw tn
traded MF135 for a 2605 4x4 &added a Mahindra eMax 22HST
Its real hard for me to climb in it. My 2605 Massey is much easier to climb on as it has a extra step. I don't think it won't b to hard to fabricate one. But apparently Mahindra doesn't offer one, nor does anyone else that I could find.
I rested on one of the rear lights and it broke off. Did put much pressure on it either, wondering if someone broke it at the shop or factory. If not, its not a very sturdy light. The housing is made of thin plastic.
On idle it rattles a lot, kinda like its under load when just sitting Bump up the rpms to about 2000, smooths out and sounds fine.
The tires don't get much grip. Went across a water saturated ditch on a angle and it got stuck, even while in 4 wheel drive. After using the bucket to back me up, I remembered that it had a diff lock. Once i engaged it, it finished backing out w/o issue.
Tractor handled well and seemed to have plenty of power. It doesn't use much fuel either :) The real test will come when the 4' roto tiller arrives.
Surprised it didn't have a mid mound pto, std. But don't think I will need one.
We bought it for the garden work and I think it will do fine.
Thanks
   / My fist impressions of my new eMax 22 HST w/ loader #5
Congrats on the new tractor.
I am always critical of anything I buy. I alter things to offset the criticism if possible. If you don't then you just "settle" for what it is.
Is the engine 3cyl? If so that would explain the vibrating idle. My old JD2210 is 3cyl Yanmar. Great engine but I never operate it at an idle. Drives me crazy!!!! :)
Yes, i am.
   / My fist impressions of my new eMax 22 HST w/ loader #7
I just noticed you went from a CUT to a SCUT. That might explain the problems mounting/dismounting. :)
Yes and a diesel.
The MF is more than twice the size of the eMax so i would think that it would the hardest to mount.
   / My fist impressions of my new eMax 22 HST w/ loader #10
Just the opposite.
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51242)
2024 INGERSOLL...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
1999 FONTAINE 48X102 FLATBED TRAILER (A51222)
1999 FONTAINE...
