3-Point Hitch Ford 4610 belt driven pump
   / Ford 4610 belt driven pump #1
xicor
Ford 4610
I have this old (new to me) 4610 I’m going through and not sure what I’m looking at here. Browsing parts diagrams online hasn’t helped either
I believe it to be an auxiliary belt driven hydraulic pump since there are 2 flares fittings but nothing is connected to it.
I also have the transmission driven pump for the 3pt and the engine driven going to the auxiliary valves.
The label is wore off so can’t get a model number but assuming it is a hydro pump I’d like to find the specs on it.
   / Ford 4610 belt driven pump #2
Looks like a AC compressor.
Really? This tractor had AC?! I’d never have guessed. Since the cab is gone I guess I’m safe to take off the belt.
   / Ford 4610 belt driven pump #5
Don't that it off set it up as a on board air (OBA), so that you have a air compressor where ever your tractor is located.
Google "belt driven OBA" the 4x4/Jeep forums are full of how to do it.
   / Ford 4610 belt driven pump #6
I have one on my IH Scout and it will run a framing nailer and I use it when installing fence rails.
2862 (A58376)
2862 (A58376)
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
Giyi Auger (A57149)
Giyi Auger (A57149)
2200 (A58376)
2200 (A58376)
2195 (A58376)
2195 (A58376)
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
