Stihl 500i Fuel Injected
   / Stihl 500i Fuel Injected #2
Stihl prices vary quite a bit depending on the country- they're usually significantly lower in the US than in most of the European countries. This saw will probably cost less than that if and when it makes it here. They often roll out new tech in their cutoff saw (that's what they did with Mtronic) and indeed there's a TS500i available in the US. But sometimes it's years between the cutoff saw and chainsaws in the US.
Two stroke fuel injection presents some different problems than four stroke. For one, the injector has to fire twice as fast, which has been a problem in some past designs. There have been some successful ones though, including the current KTM enduro two strokes.
   / Stihl 500i Fuel Injected #3
Does it need an on-board battery to run the electronics?
   / Stihl 500i Fuel Injected #6
Interesting, but what an utterly stupid and annoying commercial. A technical advance, and not anything explained about it. Oh, yeah, it cuts down trees!
BUT, does it puke bar oil all over the place when sitting?
   / Stihl 500i Fuel Injected #7
The smallest fuel injected motor we have is a Yamaha 250: this Saw is 79cc! 6.7hp, 13.6lbs.
Very interesting! And yes, a very annoying ad.
It was inevitable: FI in a small hand-held engine. I am still dissecting my first FI ATV engine, a 400cc Rotax.
   / Stihl 500i Fuel Injected #9
The Germans can build a Mercedes, BMW and Audi, but apparently not a saw that doesn't leak large amounts of bar oil. Strange! Especiallly when it represents such an environmental catastrophy.
I hate the leaking oil, but if a Stihl actually starts, I am happy and most of my larger PRO saws always have started. In that respect, I don't really see the need for FI.
   / Stihl 500i Fuel Injected #10
My Echo, Husqvarna's, Jonsered and one new Stihl all leak. They all have adjustable oilers and I have them all turned up to full oiler so mine are going to leak, I have a spot for them on a bench with pads that absorb oil based products..
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
