New Kubota 2019 X 1140
   / New Kubota 2019 X 1140 #2
:thumbsup::cool2: Congratulations! I feel the same way about my trade of my 2011 RTV1140CPX to my 2019 RTV X 1140. Wife and grands also love the new one more than the old one with no independent suspension!
   / New Kubota 2019 X 1140 #3
Congrats! Looks like a sweet machine.
   / New Kubota 2019 X 1140 #4
Did 50 hour service on my RTVX1140 yesterday and it was bad. The hyd filters are easy to reach with but the black one was a bear to get off, little room and put on by the big big big strong Kubota gorilla. Plate has to be removed to drain engine oil with 5 bolts, fairly easy but close if the machine isn't lifted, mine wasn't. The drain bolt is a 9/16 which has to use a boxed in wrench to loosen and little Kubota gorilla put it on. The plate closer to the front can be dropped a bit by removing the center bolt which helps some. Now to the engine oil filter.........a bundled group of wires is against it which requires moving to slip oil wrench on the filter and then you have enough room to turn it about a 1/4" at a time and fortunately it was not on so tight but no room for hands and even once removed was difficult to get out due to location and some cross bars. The old 1140 had the oil filter on the side of engine and easy peasy. Anyway, job done and not looking forward to changing that engine oil filter ever again. Grandson told me the machine had 51 hours on it and I didn't check because he and his siblings and wife had driven it often during the 2 months we've had it. After finishing job I saw it said 60 and I knew there was no way it had went from 51 to 60 hours in a one ime drive up mountain and down the street and home................I turned the machine off and turned back on and it has 13 hours and 60 miles!!!!!!!!!!!! Well, it's done now. I'll know to double check the report of a 14 year old now before jumping.
   / New Kubota 2019 X 1140 #5
Make sure you check the level of hydraulic fluid in the tank that's under the front passenger seat. This isn't mentioned in the owner's manual but this tank can draw down quite a bit if you lose any fluid when changing the hydraulic filters. The instructions only say to check the rear dipstick but completely ignore the front one, and it turns out that is the important one!
   / New Kubota 2019 X 1140 #6
Wondering if the low speed bothers you?
Not really. I'm in the Blue Ridge mountains, nothing is flat here or in a straight line. We can put four people in this and pretty much go where we want on the property. I like to just amble around and see things, blowing by them at 30 mph isn't this machine. We are very happy with it.
   / New Kubota 2019 X 1140 #8
I think I may have posted pics of the one I got last year. It's the 2 seat Cab model of that one. Indepeurear suspension etc. .. We have only put a few hours on it since we got it..had actually thought about selling it..but the wife was out using it today ...so I guess it's staying.
   / New Kubota 2019 X 1140 #9
Installed the two side mirrors and a rear view camera with monitor that plugs into 12 dash port for power. Camera mounts under canopy at the rera with 2 screws and back enough from edge to be out of weather. Wires run across top between rops and canopy and down rops bar in front with excess in glove box. Also installed the upper half of my $20 custom cut flat windshield and will see if I need the $15 lower half in the winter. Love wind blowing thru in summer but not in my face. Had a one piece full windshield on my old RTV1140 and kept planning to cut it in half for the 8 years I had it but never got around to it so bought two pieces this time.
UNUSED JCT 55" HYD CONCRETE MIXER (A57193)
UNUSED JCT 55" HYD...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
DIRT DOG APP48-3 (3) SHANK 48" SPRING TOOTH HARROW (A57192)
DIRT DOG APP48-3...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
