Backhoe XJ2025 cab and backhoe (2019)
   / XJ2025 cab and backhoe (2019) #1
u00rte2
Northwestern Wisconsin
2021 LS MT352HC
I have the cab on order but after seeing how close the backhoe seat is to the tractor I am wondering what has to be done to use the backhoe without removing the cab. There is a crossbar on the back section so the rear window is in two pieces. Does anyone else have a cab that can give advise?
Tim
   / XJ2025 cab and backhoe (2019) #2
I've never seen a cab on one of these other on the youtube. His name is blue tractor guy I believe.
   / XJ2025 cab and backhoe (2019) #3
Tim
When I asked my dealer to look into the cab last year. He told me the back window comes out when you want to use the backhoe.
My dealer mounted everything without modifying the cab. He just changed the seats. It is a little tight but it works. I will include a picture if I figure out how to do it.
   / XJ2025 cab and backhoe (2019) #6
It looks real good. Is the standard rollbar replaced with the cab frame? I can't quite tell. Post a few more pics when you can. I'm sure those considering a cab would like more detail. Your's is the first one I've seen on TBN.
The rollbar was removed in order to put it on. Here are some more pictures. IMG_7982.JPGIMG_7983.JPGIMG_7984.JPGIMG_7985.JPGIMG_7986.JPGIMG_7987.JPGIMG_7988.JPG
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
Unused Delta Crash...
HYSTER 50 FORKLIFT (A52472)
HYSTER 50 FORKLIFT...
2014 PETERBILT 388 (INOPERABLE) (A52472)
2014 PETERBILT 388...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
