1962 John Deere 2010 3 point not working right
   / 1962 John Deere 2010 3 point not working right #1
Shane761
Corinth VT
John Deere 2010
I attached a bush hog to my 2010 to check it out. The PTO engaged just fine no problems there, but the 3 point hitch stopped working. It would not go up or down with the lever by the seat, my control is not on the dash. That was a week ago yesterday I went out and tried it again and the 3 point hitch slowly went all the way up. Is this just in need of a new filter and oil or is there a deeper issue?
   / 1962 John Deere 2010 3 point not working right #2
Have you cleaned the screen ???
No, I bought a new filter and 2 pails of Hy-guard so I can do the fluid change. Is the filter the screen?
   / 1962 John Deere 2010 3 point not working right #4
No its on the side of the tranny housing . Let me see if I can find a tutorial for you ,
Thanks tried looking at that but it is unavailable. Bought a shop book, but I think that I know the cover you are talking about on the side of the transmission.
   / 1962 John Deere 2010 3 point not working right #7
Video was available to watch for me.. but may not be right for your 2010 tractor
   / 1962 John Deere 2010 3 point not working right #8
Ditto 2010 & 2020 hyd filters will not interchange. In fact 2010 has a screen that can be cleaned but 2020 filter must be changed if dirty. 2010 screen is accessed on RH side under operators platform.
Well removed and replaced the hydraulic filter/screen. Drained and changed the oil. The old oil was dark brown in color. Filled it back up with new oil and tested the system works a lot better now. 3 point hitch goes up smoothly , but I have to push it down by hand. Hooked up my bush hog to the tractor and the PTO stopped working I will start a new thread for that problem. Thank you for your help.
   / 1962 John Deere 2010 3 point not working right #10
That is normal.. no down pressure on the 3 ph arms.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
Lift Gate (A52377)
Lift Gate (A52377)
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
