Washing my tractor. Any pressure washer experts?
   / Washing my tractor. Any pressure washer experts?
Neighbor washed his brand new Mahindra with his pressure washer. Set too high. Blew many stickers off one side before he turned it down. Actually makes the tractor look better. All those safety stickers made it look like a fugitive from a carnival side show.
That's a big help, thanks :thumbdown:
Kidding ;)
   / Washing my tractor. Any pressure washer experts? #12
I have a 4200psi 4.2 GPM pressure washer and on one occasion used a 115 volt 3 amp 1/4 HP utility pump to feed it from a lake through 25 feet of garden hose with no problems. The pump was just a small Bur-Cam same model 300502 but now discontinued.
Any Small gas or electric (if generator available) utility/transfer pump should easily handle the GPM required. If going electric might as well go on the safe side and get a 1/2 HP unit.
   / Washing my tractor. Any pressure washer experts? #14
Would something like this work, again I'm only guessing/ assuming that if my p.w pump specs state it is a 4 gpm pump than this 5 gpm pump would be the ticket.
https://www.amazon.com/Seaflo-5-5gpm-Diaphragm-Garden-Caravan/dp/B00HI88WLQ
Says 60 psi
Funny I was just looking at one those as remembered I have a 12 volt Jabsco marine pump on my boat that provides 4.0 GPM. Assuming your hose run to the pressure washer is very short and the inlet is fed with some positive pressure from bag I don't see why it wouldn't work.
   / Washing my tractor. Any pressure washer experts? #15
Most high end pressure washers are gravity feed. I’ve seen plenty of them that even when using a water hose connection still use a gravity tank to feed the pump. As long as the hose is big enough and not a 50’ long dollar store garden hose I think you’ll be fine. One of the big diameter commercial water hoses thats short with no kinks or curls would easily flow 4gpm at low pressure.
Good thread, thanks
   / Washing my tractor. Any pressure washer experts? #18
Wash? What means this ... uhh ... wash?
Parts of my yard are almost like Quicksand. Tried awful hard to suck it down, but I beat it back and got away ... not clean though. Might be a couple hundred pounds of mud in all, but I don't think it'll work for wheel weights.
This stuff comes off easier after it dries, so I'll wait, break it off with a rubber mallet, then spray it down.
   / Washing my tractor. Any pressure washer experts? #19
Must be a tremendous amount of mud on the other side out of sight.
   / Washing my tractor. Any pressure washer experts? #20
The only washing my tractors get are when they get caught out in the rain. No trailer queens here, but they are parked inside out of the sun.
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
