Bearings in hydraulic fluid
   / Bearings in hydraulic fluid #1
bbd 25
Member
North GA
KUBOTA 6800
I had very milky white hydro fluid in my Kubota m6800. Not ran it in 5+ months, had been running smooth, maybe a little hot at times but not over heated. Since it's white I figured It obviously is getting water in hydraulic system somehow. I changed it. When I did, inside the filter and where filter connects, was a lot of big and small metal pieces, looked to be from a race of bearings. Large bearing ball was on the edge and fell on down behind where filter connects.
Very discouraging. Have large fluid filled tires. Probably needing a clutch too. Don't want to pay dealership to do, because it needs split and I know thats gonna cost out the butt. I don't make much $ with it and don't have a farm yet. It's used to bush hog family land and help other family with hay and do a driveway here and there. So I'm at a crossroads. Sell it, and be up front with buyer. Take it to dealership and drop $2500+- or figure a way to get tires off myself and start tearing into it.
Any suggestions?
   / Bearings in hydraulic fluid #2
Get a second person to assist with the tires. Keep them upright and roll them around and prop them up against a wall or something. Or unload them. Either way I'd look into it myself, but I dont know your abilities or tool selection or shop setup
   / Bearings in hydraulic fluid #3
maybe you have friendly neighbors that will help with tractor work while you save $$$money to get yours fixed?..
   / Bearings in hydraulic fluid #4
I don’t think you have to take the tires off depending on the repairs needed. I’ve split 2 tractors and left the tires on both times.
   / Bearings in hydraulic fluid #6
As 4570 said, a lot easier to split if you leave the tires on if you can, trolly jack and you can move it around..............Mike
   / Bearings in hydraulic fluid #7
Been there done that.
As long as you keep those tires upright you can roll them out of the way easily, LOL, just don't drop them.
Actually when U return them the bolt holes should still match up.
Thank you everyone, I do have a workshop manual downloaded. I appreciate everyone's input. I'm going to fix it best I can. Then sell it or trade it in. After I fix it I don't want it to be in the back of my head every time I take it out that the pump or something may go out due to pieces of shrapnel I didn't get.
In the meantime, if anyone knows where or why bearings would be in the hydo system then please let me know. It may save me a ton of time.
   / Bearings in hydraulic fluid #9
Funniest thing I heard or read all week. That’s a great theory you have there. It works IF you roll the wheel away and back EXACTLY the same distance. To the inch or less.
   / Bearings in hydraulic fluid #10
Ditto
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2002 International 9200i Truck (A52748)
2002 International...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
3 New 14in Premium Diamond Blades (A50322)
3 New 14in Premium...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
