Bucket on White 1370 Stutters After Fluid Change
   / Bucket on White 1370 Stutters After Fluid Change #1
farmermaker
Oliver 1365
Hi all,
I recently changed five bad hoses on our '74 White 1370. The tractor has been around the block of few times. I drained the fluid, changed the filter, replaced some hoses. Now the bucket stutters on the way up every time. This has been going on for a week now even after frequent use. It also seems to have loss some holding capacity meaning the bucket lowers slowly when there's weight in it.
I read online that I should have cleaned the sump filter but I couldn't find it. I'm new to hydraulics but I've been wrenching for years. Can you help a farmer out?
Thanks!
   / Bucket on White 1370 Stutters After Fluid Change #2
Hi all,
Thanks!
Lets start with how many hoses are on your loader valve. 6 or 7
I suspect you have a hose in the wrong place which is common when someone is replacing hoses and not doing it one at a time.
Dave M7040
Dave M7040
There are four hoses coming from the valve and there's no way I placed the hoses in the wrong place since I labelled everything. One of the four cylinders was leaking this morning so we brought in for repair. This might be the source of the stuttering. I will update once all four cylinders have been checked out and repaired where needed.
Thanks!
UPDATE:
All four cylinders needed new rods and some odds and ends. It was an expensive repair. We're about to put them back on the tractor.
BUT...
I forgot to label everything! There are four quick connects and each cylinder gets two hoses. Any tips on reinstalling these cylinders without having labelled anything? Is there any harm in trial and error?
It's a KMW K 120 loader on a white 1370 tractor. TIA
   / Bucket on White 1370 Stutters After Fluid Change #5
Start by installing the lift arm cylinders and get them working properly.
Don't install all 4 cylinders to start with as it will just complicate matters.
The quick connects for a pair of cylinders will be in line with the valve control handle(s) not side by side.
Make certain the action of the joystick or levers are proper. I know of a guy who tried driving his tractor when the loader valve action was opposite to what it should have been.
Pull back for up and push forward for down. The end result was he rolled a large bale off the loader and unto him. He suffocated under the bale.
Dave M7040
   / Bucket on White 1370 Stutters After Fluid Change #6
When you say bucket up, do you mean loader up?
Do you mean hydraulic fittings when you say quick connects?
Each end forward and back port of the lift cylinders get plumbed together. Then, same with the bucket cylinders.
Not much harm in trial and error, except unecessary mess.
I bet, air was getting into your cylinders and it will be good now. Having said that, having had basically the same tractor, I developed a hydraulic suction leak that I never managed to fix and traded the tractor in.
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
2016 R&R Products 331 LP Reel Mower (A51694)
2016 R&R Products...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
