New poster / jinma front wheel seals
   / New poster / jinma front wheel seals #1
Shrpshotr45
Jinma 284
First, im new to posting but not new....i have learned a lot from this forum in the last 3 years. We have "quirky" little tractors....i wouldnt recommend anyone not willing and able to put in the "elbow grease" purchase one. Ireallyhave had minimal problems.....but if i had to pay someone else for every one i would be broke or have a yard ornament
That said, i love my little workhorse.
I would have never signed up for the forum except for a failed front axle and seal this week. Circle G took care of the axle but i forgot the seal. I needed something local...ASAP....4-5 HOURS OF RESEARCH i found a domestic part number (National 225040) available at almost any car parts store. Figured it would last a couple weeks until i could get the 2 seals specified....you all know there are 2, one inward for keeping oil in and one outward to keep out water/debris.
Pleasant surprise....225040 is a true "double seal" matches the original inner dimentions 50x72x12 so effectively replaces both chinese seals at a single price and is readily available.
Hope this helps someone here.....even though i have never joined and posted, you guys have unknowingly helped me a lot.....time to give back.
Cant figure out how to add a pic here
Thanks
Gotcha....
   / New poster / jinma front wheel seals #8
come on one more post and you will do it....
So what other front differential problems you guys had besides the common hub/stub axle breakage?
   / New poster / jinma front wheel seals #10
Driveshaft down to front axle and their low budget version of a CV joint. Overloaded they sometimes pop the balls out...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHGW6796 (A51572)
2016 Freightliner...
2018 FREIGHTLINER CASCADIA SLEEPER (A52576)
2018 FREIGHTLINER...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
