Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze.
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #11
Thanks! Seems to be a good 4 in shorter but the fully extended position on yours seems to be ok for a mechanical thumb. I'm toying with the idea of replacing the brace with a hydraulic cylinder. I think for that I would go longer, especially if the thumb gets a dedicated valve. I'm still in mild research mode so this thread is giving some good data points when it comes to cylinder sizing.
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #12
My new thumb doesnt retract far enough to get out of the way either. I wonder if it is the wrong thumb - perhaps for a bigger hoe?
Here is my old machine - notice how the thumb retracts further for storage.
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #13
Just got my tractor and have the same question/issue. May take it apart and shorten about 3” on the slider arm and redrill the hole. Appears that for some reason they lengthened the throw on it. So far with working in the yard on brush and pushing things around I don’t need the last 2 positions of travel.
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #14
Double check everything and make sure it isn't hanging somewhere. Factory thumb is supposed to go into storage mode and lay back relatively flush. That said, I liked the BXpanded factory fit thumb better than the Massey oem thumb. I liked the curvature of the claw better and thought it the be heavier duty as well.IMG_20190523_175957.jpgIMG_20190523_175940.jpgIMG_20190515_134432.jpg
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #15
Double check everything and make sure it isn't hanging somewhere. Factory thumb is supposed to go into storage mode and lay back relatively flush. That said, I liked the BXpanded factory fit thumb better than the Massey oem thumb. I liked the curvature of the claw better and thought it the be heavier duty as well.View attachment 606402View attachment 606403View attachment 606404
My BXpanded thumb got here yesterday so I'll be putting that on this weekend; I've got a bunch of rocks I want to move!
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #16
Awesome! It's a great tool! It's an absolute breeze to install and works like a charm. As soon as it dries out so I can get out back I've got wood to cut, brush piles to grasp and stack and holes to dig with various rocks/concrete chunks to move!
PS, I wiped the shafts of those large brass bolts down with no2 lithium grease just to help them articulate easier when deploying the thumb. You may find it helps a bit vs dry metal on paint.
   / Factory Thumb for GC1700 CB65 Hoe, works good, install is a breeze. #17
Thanks - great idea. I usually keep a tub of red #2 lithium around for assembly.
Killbros 375 Gravity Flow Wagon (A56469)
Killbros 375...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
UNUSED FUTURE FT-VB59 59" HYD VIBRATING BUCKET (A57193)
UNUSED FUTURE...
CASE IH STEIGER 400 HD TRACTOR (A57192)
CASE IH STEIGER...
2024 BOBCAT MT100 STAND-ON SKID STEER (A52707)
2024 BOBCAT MT100...
