What is the best way to mount birdhouse on a pole?
   / What is the best way to mount birdhouse on a pole? #1
robbyr
western east central texas
ford and mahindra
Not sure how to put this on a pole. Do not have a pole yet.
   / What is the best way to mount birdhouse on a pole? #2
If one end of the pipe threaded screw on flange than fasten to bottom of bird house
   / What is the best way to mount birdhouse on a pole? #3
If top (marked) is strong enough, a screw eye each end, wire across with piece of rubber hose, hang over tree limb.
Or pipe flange on bottom, about 2" pipe.image_2019-06-19_18-29.jpgblack-pipe-fittings-521-605hn-64_1000.jpg
   / What is the best way to mount birdhouse on a pole? #4
One thing I have found helpful when setting out bluebird boxes is to mount the box on a section of heavy EMT. Then I drive a T-post into the ground and simply slide the conduit with the box down over the T-post.
Thanks. Thinking about the flange idea.
   / What is the best way to mount birdhouse on a pole? #6
Or pipe flange on bottom, about 2" pipe.View attachment 609699View attachment 609700
I mounted my bird feeder via the flange method; used about 5' of gas pipe and put a flange on the bottom also, to provide stability without cementing it in.
   / What is the best way to mount birdhouse on a pole? #7
I too used the galvanized flange and galvanized iron pipe. I used my old satellite dish turned dish-down on the pole to keep squirrels from climbing up it. Just used some worm hose clamps above and below the dish to hold it there but it lets it tip if something tries to grab the edge to climb up. Has worked well for years.
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2007 Ingersoll...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
