Tire chains GC2610
   / Tire chains GC2610 #11
This thread has been helpful in understanding that I only need chains on the rear wheels (as I do now on my 2WD Bolens HT20) rather than all four.
Now to source them and determine the best style.
   / Tire chains GC2610 #12
I found out early in that living on a very steep driveway using the front blower and rear blade I had to put on front chains in order to steer when turning around to head back uphill. I pull it out of 4wd whenever I’m down to pavement and I’m careful but I needed them.
We’re moving to a “normal” home with only a slight inclined drive so I will hopefully never have to put the fronts on again.
   / Tire chains GC2610 #13
I've only ever used chains on the rear of mine, and that's worked very well for these icy times we get once in a while. (Last winter was terrible in that regard!)
I also have a steep drive, and found that the BH on the rear really killed the ability to steer. Worked great for traction but put too much weight on the rear so that, headed uphill, the fronts had very little weight on them and steering control was non-existent. Removed the BH and all was well.
I see where you also use a back blade, pixguy. You might consider trying it without that on, though it sounds as if your steep driveway may no longer be an issue.
Stevens, I got some chains that have the "biting crossbar" bits on them. They've worked beautifully, and don't mark up my paved driveway much at all. Similar to these: https://www.northerntool.com/shop/t...MIl_b3n-b34gIVEZJbCh3ImgMBEAAYBCAAEgLVCvD_BwE
   / Tire chains GC2610 #14
   / Tire chains GC2610 #15
   / Tire chains GC2610 #16
Yes, those are more like what I have. A Norwegian design, apparently.
Informational Lot - Shipping (A56438)
Informational Lot...
19010 (A55851)
19010 (A55851)
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
