I think it's time to look for a harness.
   / I think it's time to look for a harness. #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I'm getting to a point where I don't feel comfortable on a roof, even a low pitch. On shingles it isn't so bad, but on metal, I just can't get footing I'm comfortable with. Between my back, hips, legs, knees and ankles, coupled with a faltering sense of balance, I just can't stand up like I see others doing.
Searches for terms like 'climbing harness' or 'safety harness' haven't come up with what I think I need which is a vest type, over the shoulders, around the waist and I'm not sure about leg straps. I want to be able to tie off to a variety of things including beams, rafters, or a tractor or other tie point on the ground by means of a rope over the ridge.
I've got a lot of things to do coming up, but I like my bones in one piece.
Ideas?
   / I think it's time to look for a harness. #2
I had to do quite a bit of work on a 10/12 roof which really sucked. I had a real climbing harness but I found a strap around my waist was as comfortable. Sure it wouldn’t be good for actually climbing but it’s only job is to prevent you from sliding off.
   / I think it's time to look for a harness. #3
are you looking for a fall arrest harness or a harness that actually holds you in place?
   / I think it's time to look for a harness. #4
4 point or 5 point climbing harness or industrial harness. I assume eBay would be the place to start- all you need is an old one for occasional use. It’s not like you will be sitting in it all day cleaning windows on trump tower.
I don't like belts, so a waist only harness would have to be a few inches wide. I'd also be concerned that if you DO happen to fall, there might be some serious stress on the midsection if the rope were a bit too slack.
That. I need freedom of movement for placing roof panels and use of tools.
Yeah, I don't need a high dollar certified model.
   / I think it's time to look for a harness. #6
safety harness kits run about 125.00 includes harness , rope , slide and one anchor . They can be bought at box stores or roofing supply .
   / I think it's time to look for a harness. #7
Any harness without leg straps would probably be used. Check fall arrest harness, anything comfortable will cost over 100 easily
I've never fallen and have never come dangerously close. But I do NOT want there to be a first time.
   / I think it's time to look for a harness. #10
I'm getting a basic bucket kit like what M5Farms suggested before I get on a roof again. The last time I shoveled mine off I called my neighbor first and asked them to come looking if they didn't hear from me in an hour. I don't bounce the way that I used to.
FORD 2000 TRACTOR (A51243)
FORD 2000 TRACTOR...
Land Honor Quick Attach Big Arm Backhoe (A50515)
Land Honor Quick...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
