Tractor Sizing Buying a Ford 340A trying to figure out total weight for hauling
   / Buying a Ford 340A trying to figure out total weight for hauling #1
jpatt5
Ford 340A
I'm buying a ford 340A with a loader and I'm trying to figure out the weight of the tractor with a loader. Tractor Data says the tractor weighs 4615 lbs and with the loader 9100 lbs. Surely the loader doesn't almost weigh as much as the tractor. It says it has a ford 745 loader. Any help on this would be great. Trying to figure out if I can tow this with my tundra/equipment trailer or if I need to get a bigger truck to go pick it up.
   / Buying a Ford 340A trying to figure out total weight for hauling #2
My guess is that your loader weighs approximately 2600 lbs.
That would put your total weight at about 7200+ lbs.
Probably just a bit heavy for a 10,000 GVW trailer.
You will likely need a 12,000 lb. trailer and vehicle tow rating.
   / Buying a Ford 340A trying to figure out total weight for hauling #3
I'm thinking 9100 lbs. is pretty close if it has a backhoe like lots of them do. My old IH3414 with a loader and hoe is about the same class and weighs somewhere north of 9000. I think I remember reading the hoe was around 2500 lbs.....Dan
   / Buying a Ford 340A trying to figure out total weight for hauling #4
The OP states that he is buying a Ford 340A, "with a loader".
Nothing is mentioned about a backhoe.
   / Buying a Ford 340A trying to figure out total weight for hauling #5
For sizing a trailer Fred is probably close enough with any possible error on the side of caution.
Thanks for the responses! I ended up renting a f250 and used my equipment hauler to be on the safe side. Although my tundra probably could have handled the load, it is only rated for about 7700 lbs.
17301 (A55853)
17301 (A55853)
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
